IDAHOTUNERS: Big Bore Sr22 Twinscroll Gt30 Build
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
i couldnt find any the correct size. so these rings dont need to be gapped. hmmm ight be worht it
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
idahotuner wrote:so these rings dont need to be gapped. hmmm ight be worht it
Not quite. They are file fit, including the oil ring rails.
idahotuner wrote:i couldnt find any the correct size.
http://www.totalseal.com/Custom.aspx
garagelu
Car: 1995 240sx w/ sr
Can you tell us how much mazworx is charging to do each job? Obviously mazworx is the best in the sr world and I would imagine they charge quite a bit because of it. I just want to know how realistic it is for me to send them my stuff to get worked on.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
garagelu wrote:Can you tell us how much mazworx is charging to do each job? Obviously mazworx is the best in the sr world and I would imagine they charge quite a bit because of it. I just want to know how realistic it is for me to send them my stuff to get worked on.
for how much and the experience they have doing this stuff. the price is well worth it.
you get a core refund and arp main studs. everything it decked to seal correctly, the block is completely cleaned, oil holes cleaned, the main bearings are oil groved. new oil pump. bored and resleeved, with a guarantee on the sleeving. http://www.mazworx.com/index.p...=2750
they have block al ready near completion then you tell them what you want. they do it to the block they have, then shipped it to you after a deposit is made then you ship your block and stuff back to them for a partial refund on your deposit.
240sxFTW
Car: 89, 240sx coupe
Cant wait for another build thread by you. subscribed
Stripes
Car: hatch, coupe
Do you need a new crank shaft since you are doing a 2.2? Or are the sleeves bringing you back to standard bore? I'm a bit confused.
MastaYu
Car: 92 Nissan 240SX SE HB
this is gonna be fun to watch
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
Stripes wrote:Do you need a new crank shaft since you are doing a 2.2? Or are the sleeves bringing you back to standard bore? I'm a bit confused.
no
no actually. i am gaining the displacement in the over bore i am doing. stock increasing each cylinder by 4 mm
bring it to 2.2 ad a stoker kit depending on the kit could pump it up to a 2.4 . i saw one kit that kep the 86 mm bore and stoked it up to a 2.4 i think it be awesome to compine that kid with the over bore i am doing and try getting 2.6 liters that is almost a full liter more of displacemnt
White Comet
Car: fc, s13 and mazda6, Sierra
my math is rusty, but 2.6 is slightly half more then 2.0, not a full liter more
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
lol werd i know, i was slightly exagerating but the idea of making a 2.0 liter a 2.6 would be awesome
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
IDAHO! Dude I'm sad to hear you melted your rings. This thread should be great, and I'll be checking in more often now that I know it's here!
What you document on doing to your SR this time will be more extensive than most of the nico population haha! I don't even know exactly what a valve angle job is, care to elaborate or point me to where you did?
Dude your dad posting and a new engine build thread? What could be better!
Did you have to reshim the lifters last time I forget? You only have to do that once or twice right?
Gonna be a great process, nice shop I'm jealous.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
Didderson wrote:IDAHO! Dude I'm sad to hear you melted your rings. This thread should be great, and I'll be checking in more often now that I know it's here!
i know tell me about it lol
3 angle valve job. the valve seat where the valve seals against the head usually has 3 angles fro mthe factory. the highest angle is for airflow then the two lowest are to help the valve seal correctly. the difference between these angles is usually 15 degrees.
usually 60 45 30 are the angles.
well mine are burnt so the valves arnt sealing correctly.
3 angle valve job implies regrinding all of the seats with new angles slightly different then grinding the angles on the valves slightly different to, off by maybe 1 or 2 degrees then the seat. to get more pressure on the seal point causing it to seal better.
we did a whole class and then a 3 hour lab on valve seats and such.
yes i reshimmed. shimming is not suck a huge deal with hydraulic lifters. the main thing is to make the sure rocker arm is sitting level on the cam lobe
240sxFTW
What are you taking Idahotuner? Im interested in your field of work when I graduate.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
240sxFTW wrote:What are you taking Idahotuner? Im interested in your field of work when I graduate.
i am going to school at WWU for an automotive management/ tech degree
jr_ss
Car: 95' S14
You're going to need a new trans... That Sr trans isn't going to handle the amount of power your going to put through it, especially if you plan on dragging it or flogging on it alot..
Great build up Potato... Looking forward to seeing the results.
srdub-t
Car: white 91 SR22 powered coupe 240sx, 95 black c36 amg
super sick... im almost done with my mazworx 2.2L all im waiting on is a haltech e8 witch im saving up for.. dam did my build get expensive. the motor was bank, but so was the exedy twin disk, the gt3567r, the proper fuel setup, and all the other expensive parts that i purchased lol. are you going q45 TB? im to broke right now lol ima use the stocker and upgrade that later.
240sxFTW
How long of a term?
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
jr_ss wrote:You're going to need a new trans... That Sr trans isn't going to handle the amount of power your going to put through it, especially if you plan on dragging it or flogging on it alot..
i can pick up extra ka trannys for a pretty good deal. then swap bell housings
240sxFTW wrote:
How long of a term?
its a 4 year degree butthe program is awesome and the facilities are very nice. we havea brand new AWD mustang 1400 dyno. and i get free dyno time YAY.
White Comet
idahotuner wrote: i can pick up extra ka trannys for a pretty good deal. then swap bell housings
thats exactly what i did
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
srdub-t wrote:super sick... im almost done with my mazworx 2.2L all im waiting on is a haltech e8 witch im saving up for.. dam did my build get expensive. the motor was bank, but so was the exedy twin disk, the gt3567r, the proper fuel setup, and all the other expensive parts that i purchased lol. are you going q45 TB? im to broke right now lol ima use the stocker and upgrade that later.
yes my budy offered me his q45 throttle body, but iwill have to havea new flange welded on my intake manifold. and i dont want just anyone touching a now 600 dollar greddy intake with a saw and welder.
i might look into cahnging the angle of entry fro mthe cold pipe as well.
EssThrteen20
Car: 93 Nissan 240sx
I followed your last build and I'm definitely going to follow this one as well. Your build is gonna be sick, good luck
xhefri
Car: Toyota MR2
My MR2 will smoke your car dude.......:-) Well, ......maybe eat your smoke I should say! Cool thread!
White Comet
the mr2 has a sexiness factor greater then an s13
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
xhefri wrote:My MR2 will smoke your car dude.......:-) Well, ......maybe eat your smoke I should say! Cool thread!
hehe i was going say i remember you trying to race me the first time i drove it o nthe street. hahah
White Comet wrote:the mr2 has a sexiness factor greater then an s13
its does have that i will admit. mine is more of a brute force look
White Comet
true, i miss my brother having his sw20
xhefri
Car: Toyota MR2
well said! That is what I was thinking!
Stripes
Car: hatch, coupe
I am curious now as to exactly why 2.2L kits come with a new crank. What about having a 2.2 stroker would leave you with the need for a new crank shaft? Or do they just include it because it is better balanced or lighter or whatever? Say I was to buy the Tomei 2.2l kit. Would I HAVE to use the crank they include or would my oem one work just fine?
srdub-t
no stroker kit here. just 90mm pistons and some sleeves
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
you can change the displacement of your motor two ways over bore it or stroke it.
over boring is making the diameter of the piston bigger
stroking is making the distance it is traveling longer.
both ad displacement.
combine them and you will have the benifits of both.
stock sr20 hasa 86mm bore X 86mm stroke. change the bore or the stroke and do the math.
Stripes
Car: hatch, coupe
Thanks, it all makes sense to me now. So if you were going to stroke a motor, not only would you need a different crank, but wouldn't you need shorter rods as well?This is getting me thinking.... 2.2l stroker kit + .2l over bore......hmmmmm
