thanks man. i got 1000km on my motor pretty darn fast. 4 days actually. but i dont have a job right now. so it made it easy.nevertheless wrote:yay for no oil leaks. Im currently breaking in my fresh SR, Im only half way..subscribed.
thank you for doing that.OutToWinPAHC wrote:Topics Merged.
Wow, mine was ~18-20psi at hot idle (900 rpm and ~190 degrees) on 15w-50 Mobil 1 and Mobil 1 filter. Now running ~15-16psi on 10w-30 Mobil 1 and PureOne filter at same specs. Motor runs 55-60 psi at 3200rpm no load hot (FSM calls for 46-54psi) and 75-80psi cold start. I wonder if it's the cheaper sensor on the short sweep electric Autometer bc my engine is super clean inside. I've also read on other forums (one vette forum comes to mind) that Mobil 1 tends to run a bit thinner than some oils and that PureOne filters are a bit more restrictive to flow in favor of better filtration. Hopefully, I don't have any issues. Thanks for the info. Most people I had seen with ~25psi were running a bit higher rpms at idle.idahotuner wrote:ran at 30 psi for a little bit then dropped to 25. . now its staying solid
LOL Lovin the sig pic, btw.idahotuner wrote:i baked brownies with something in them once but thats a different story. the results were hilarious though.
