as far as machine work mazworxs prepper block. check them out http://www.mazworx.complayero_loko wrote:idaho,
did you ordered your t/s kit from full-race? when do you think you'd be able to begin tunning? quite interested in the number you could get... can you send me a pm in regards to the maching work you have done to your block...
Shaft,
whos the red head?
it should spool about the same because if you look at the gt3076 twin scroll kits they spool about 300rpms later then the ss gt2871 .64 so my over bore and higher compression should move it back to the same spot as the gt2871.EssThrteen20 wrote:Yo Idaho, i swear i remember reading something you posted but i cant seem to find it now. You said with your 90mm overbore your 3076r will spool like your old 2871 setup? If this is true you have me sold on overboring my block, as I was originally planning on leave it stock bore.
no i dont have them, but yes you need the lower trim piece, i think they come with their own key and lock assembly usually.playero_loko wrote:Idaho,
got one question for you, you do have the kouki tail lights right? do you need the lower trim piece or can you use the one that the hatch comes with? ive been thinking about getting some but wasnt sure it was needed... also do you know if the usdm locking assy works with the jdm parts
you actually dont need the lower panel but it helps everything fit nicer. without the lower panel, the center garnish just doesnt sit flush with the lower panel since the usdm panel is sunken in. the usdm lock stuff doesnt work. but i'm working on a way to modify the usdm locking assembly.playero_loko wrote:Idaho,
idaho,idahotuner wrote:madegt2871 .64 at 24psi416 rwhp and 350 lb tqfull boost 3800
want to makets gt3076 at 30 psi550 rwhp and 400 lb tqfull bost at 4000 rpms
i had a ECU tune by enthalpy, so i am not sure on the specifics exactly, yes i think you will be able to break 500 fairly easily, and 450 should be a piece of cake.playero_loko wrote:
idaho,
what did you have for tunning, a pfc? if so, what would you grade your tunning from 1-10... do you think that with my set up i could possibly breake the 500 mark? i think we have the same stuff except for the overbore and p&p job... do you think 450 could easily be attainable?
i am waiting on my rotating mass to be balanced, and only have 4 more weeks tell i leave for alaska to go fishing. well i get back from fishing august 21st, that when i will be ordering all my parts, hopefully full race will have all the stuff stock piled so i dont have to wait for them to make the parts, but i figure 2 weeks to get all my s***. probably an other week getting stuff all in the car and together.idahos13 wrote:so when do you think this bad boy is going to be done? I live in Idaho by the way
thanks for that info, its nice to hear what other people have to say, i am unsure as why exactly you need to change the oil right away, because seems like that is when the motor would be the cleanest, but maybe it is to get all the dust and s*** out from the oil circulating.V8slayr wrote:Idaho, I wouldn't worry too much about driving the car easy for almost 1,000 miles. I just did a rebuild on mine too. I'm not shooting for the kinda power you are but I used stock rods, OE bearings, ARP fasteners, and 87mm 9.0:1 CP pistons w/ stock sleeves. I'm using an Enthalpy ECU as well and have consulted my builder as well as Scott as far as break in goes. I drove the car easy for about 300 miles and then began to throw 15 psi to it w/ my T3/T4 50 trim. Scott said that he will build a motor, let it idle for 30 min then change the oil and go straight to the dyno @ 14 psi. Apparently the rings need a good bit of cylinder pressure to seat properly. Anyway, I have had no issues whatsoever w/ my motor since I started driving the car hard around 300 miles or so. My motor still only has 800 miles on it and I've done 7500 rpm pulls at 17 psi, and the car feels like it makes around 350 plus RWHP at that boost. So in my opinion w/ my own rebuild experience drive the car easy for a couple hundred miles, obviously change oil, and gradually start boosting it. It has worked well for me.
hehe whats august nights? lolboro drift wrote:Hey Ben, you're gonna have the car done in time for Hot August Nights, right?
idahotuner wrote:
no over sized oil pan. not sure which one. might do a welded sheet metal one or a freddy one that i will clean up.
