the goal was march, but i am thinking the middle of febuary some time. but to be more realistic. probly middle of march still. depends on if alot of things come togethers14tan wrote:Damn Ben when is she gonna be runnin?!
what does that intail?duffman1278 wrote:Take out the IACV and clean it.
yea my dad said we should figure soemthing otu for that. lolDidderson wrote:I wanted to say 1 more thing. Try and fix the roller coaster heater core hoses for me? lol. Get some nice metal 90deg. bends made out of copper or something.U should clean the block while its still out. still a bit of grease near the water pump.
Are you planning on pulleys? if so i'm curious as to what brand.
i know it looks like it is flexing hahaajones1229 wrote:Your motor has a beefy look to it that I really like and in the words of Terrel Owens "I love me some meat!"
Looks crazy good.
the iacv is on the bottom of ur greddy manifold. it's the thing that i asked u about coolant lines for it. the little thing w/ the idler screw on it. take that out and spray carb cleaner in there.idahotuner wrote:
the palce near the water pump has been soaked down with gunk. and pressure washed and it still looks liek that.
Good pads on astock brakes will work just fine.White Comet wrote:very true, but even good pads with stock s13 brakes doesnt do nearly as good q45 brakes.
def dont rock stock brakes with an sr, especially one as modded as urs. even with a stock sr the s13 brakes suck. ask anyone that ever been in my car. thats why i got q45 brakes
Rutland Stove Cement, found at Ace Hardware.idahotuner wrote:for putting together the turbo and o2 extension. will thread lock work fine. or is therer something else i should use
7 heat range. Gapped to .022 -> .025 Iridium is best, but the old standby BKR7E-11 will do well. Just change them every oil change or every other.idahotuner wrote:what heat range should i use for spark plugs?
yea my dad helps me with alot. mostly body work cause that is his thing. he actually liek doing that unlike me. hahacodyace wrote:Nice to see you finally on this!! Also, props to having your Dad help you out. It's always reassuring have the 'old mans' advice I'm sure
That little plug/wire thing is just a secondary ground, off of the factory oil/air seperator (back of drivers side of engine)...
However, with looking at 350+ hp, Z32 is the only option IMO.
