Idaho Tuner's 240/|SR Build thread
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
i dont know. i think i might just keep stuff the way it is until i get back from next summer. i just need to get the nissan running like it was again.
mRodiek
Car: Stock Hatch
i didnt know anything was wrong..what happened?
Kalypso
update please
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
well it runs and boosts all right at 10 psi.
#1 it isnt putting enough of a load o nthe alternator at idle so i all ways have to have my lights on or defroster or something to keep the alternator loaded up so the idle doesnt pulse and want to die
cause: could be the gasket on the o2 housing to down pipe is **** and so air is pulsing in and out from there at an idle cause the o2 reading to screw up. need to check to see if this is true.
#2 been over heating again. it was a new thermostat in it but likes to heat up slow then goes really fast from normal operating temp to hot. 180-230* F takes a long time to drop back down. and i have waht looks like oil in my coolant, but not really oil. just greasy stuff.
cause: possible over heating cause the head to warp. even though compression test was fine. but i need to perform a leak down test.
last when boosting under a heavy load it misses really bad. and acutally makes a sound like air blowing out of a small hole really fast.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Dam ben, problem after problem with this car. Mo money mo problems lol Get the FD!
Kalypso
thats managable, as long as you put it on a stand and give it the thorough treatment you'll be fine...
money is the only obstacle.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
money isnt an issue. i havea full shop at my finger tips and i get credit for everything i do. i get 40 to 60% of parts. the main things i will have to do is mill the head and block. and just assemble is again.
Kalypso
oh cool... the mood in this thread was real somber like somebody died, lol.
but it sounds like sh*t is cool
freakyjason
Car: 1990 240sx
After seeing all the little issues you've been having with this car, I'm starting to second guess my build. Oh well, i already bought all the parts. Maybe i'll just beet the piss outta it for a while once i get it together and then sell it to some drifter wanabe for 15k. Oh well, good luck with getting it running well again. I'll hopefully have the cams, injectors and maf on mine over spring break when i get my ecu from jwt.
Modified by freakyjason at 11:49 AM 1/21/2009
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
good news its not a warped head. .......... its f'ed pistons rings. the tear down starts tommorrow
duffman1278
Whore the pics of the tear down!!!!
mRodiek
Car: Stock Hatch
Nooo way, that really sucks!!I cant say Im too upset though, at least this thread will come back to life
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
i actually will probably open another thread in sr20det section. going to go a little bigger bore. like .02 over and cp forged pistons, and eagle rods held together with arp stuff.
RCCC_DRiFteR
Car: '89 Nissan 240sx
Been long *** time since I've been on Nico. I remember last time around when I did my SR swap finally that you were having overheating issues and swapped out the thermostat. But do you think the overheating screwed up your rings!?!?
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
over heating and maybe my stock block just wasnt up to the taske. of holding the higher boost levels
Slideways^Jordan
Car: 1989 240sx Coupe-1991 240sx Hatch back
idahotuner wrote:i actually will probably open another thread in sr20det section. going to go a little bigger bore. like .02 over and cp forged pistons, and eagle rods held together with arp stuff.
That sux bro, Good luck with it all. Mine been running strong since the tune haven't had any problems really at all but im going get different cams cause i don't like the power band and theirs like not enough torque really. How much torque did your 264 feel Ben? What was your dyno sheet and hp and torque numbers again.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
i love the 264 cams the power kicks in a sweet spot. 3-7 grand. i got 350 ft lbsat 24 psi.
thinking i will change out internals for now. then later next fall go to a top mount t3/t4 50 trim or gt3067
sommmatt
Car: 1989 Nissan 240SX
Man, after opening Diddersons thread to find out his car was totalled, I was expecting the worst in this thread for some reason! I feel better knowing it's not the case, lol.
White Comet
Car: fc, s13 and mazda6, Sierra
get on the ball. diderson's car was totaled months ago
freakyjason
Car: 1990 240sx
Wow! Sorry to hear you gotta take it all apart now. Oh well. Now with the new forged internals you can run mo boost 'cause mo boost is mo betta!
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
with forged internals i will go top mount twinscroll gt3076r. apexi de jetro PFC. aim fora 500 to the wheels.
the new turbo wont come tell next fall unless. i might be able to pull off enough stuff to sell to get the fc and turbo set up by selling some parts i have.
gt2871r .64 turbo- 1000adapter peices - 30MR manifold - 45MR o2 housing - 20CS ss turbo lines- 80t28 return - 20piping pro intake plus couplers - 35 apexi z32 filter - 402 z32 mafs - 200Enthalpy tuned ECU. - 350
that gets me- $1,8** thats barely enough for my manifold. lol
this is what i will get http://www.full-race.com/catal...=1748
lol 1800 is half of that.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
oh i for got i will add a bee r into that thats 180 moresell my mini bike for 100
thats 2000 lol hmmmmm.
White Comet
wait o your selling the parts listed? if so i call dibs on the turbo lines. they'll work on a t25 right?
mRodiek
Car: Stock Hatch
If you would have posted that Monday, you woulda had like $270 direct from me! Too little too late I guess lol
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
White Comet wrote:wait o your selling the parts listed? if so i call dibs on the turbo lines. they'll work on a t25 right?
yes they will. but i had one guy interested in buying it all together so i will see. the only thing holding me back right now. is if i will have a place to keep my car over the summer that will be safe. as soon as i figure that out. i will pull that stuff off and sell it.
White Comet
ok cool, if that other guy falls through. i'm all over the lines. i don't need the whole setup (even thoguh i want that turbo) but i need lines before i put my t25 back on
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
here is my fs thread. zer...mitor
duffman1278
You're not going to reuse the turbo lines for your other turbo?
Man can't believe you're selling all your stuff! I want your turbo, but I'm not working many hours
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
i need different turbo lines fora top mount turbo
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
let me point you to my new build thread zerothread?id=404493
