articzap wrote:People are all over the place and assuming the wrong things way to fast. This forum jumps to the wrong conculsions way to quickly.
You messed with the TB and it won't start now. So lets narrow it down to it might not be getting enough air to start. Make sure the TB adjustment screw holds the blade open ever so slightly. Also check your ICV and idle screw on the manifold.
A tb screw wont keep it from running, just idling.
If you dropped that CAS, I would start with that. I dropped mine a few years back and although it didnt fail, it drove me to the brink of insanity because I wasnt making the power I should have been.
It finally failed on me the other day, all 4 of them. They are 20 year old optical sensors I think??
