I wish a had a Chevy 350.
zmannz
Car: 89 s13 coupe- track car
92 s13 coupe- dd
PapaBurgundy wrote:She runs! Thanks everyone for your help and suggestions, turned out to be my fault, as most car problems are. Just some bad maf wiring and a huge vacuum leak as well as a stuck open tb. Thanks again for the help.
Hells yeah, I knew there was a leak in there. I second gabby's post... Glad its running!
bentvalves
Car: 89 Silvia K's
what led you to believe that the CAS needs to be stabbed with the motor at TDC, did you find this in the FSM??
update this thread damnit.
PapaBurgundy
Car: 1991 240SX coupe SE CA18DET. 99 Dodge 2500 Cummins TURBO DIESEL 5spd.
Sorry for not updating, I rarely get to my parents to use there computer. I really dont know how it happened but we just somehow wired the maf incorrectly, even though I swear I checked it a thousand times. The vacuum leak was the gasket at the back of the intake manifold being half missing and the stuck throttle body was its a ka-e tb and I didnt think to check if my throttle cable had enough play. About the cas to cam intercourse at tdc, I really cant remember where I heard that, but thats the only place it worked so I thats what I did.
