Edited for stupid commentary.surfwax95 wrote:Not everyone with low post-counts is a douchebag.
basically what I said. stock 240's are slow and are going to be slow until you put money into themHashiriyaS14 wrote:Don't expect to win much either, because you won't.
neagan wrote: what else did you bring to the table that was useful to this guy?
ask anyone who really puts time on the track. launching is half the race.mmatl16 wrote: take your car to the nearest legal drag strip and work on launching. nothing you do is gonna help your times with 20 dollars unless you gut your car down to the metal.
how bout this if you think all your tricks help so much you come up here to sac raceway and me and you will take a couple runs. ill let you wrap up the whole car in tin foil if you want.neagan wrote:come out to Infinion raceway sometime for our Wed night drags
o im sure your a savage drifter and and ur always coming intom corners at a 100mph. tell me who do you drive for?neagan wrote:Ever have a fatty spring-time insect hit your windshield when you're drifting into a corner at over 100mph? It'll scare the hell out of you and you'll instinctively jerk the steering wheel.
----------------------------------------------neagan wrote:C) Index your plugs
D) Tyre air pressure
F) Wax the entire car including the windshield with 3 full coats of wax.
M) Take off weatherstripping at back end of hood where it butts up against the cowl, or take washers and stack/shim the hinges so that heat off the top of the engine is being sucked out over the windshield.
Okay, so we have established that he is street racing...neagan wrote:Remember me asking him what type of street racing he was going to do?
Once again, the kid is street racing, not breaking speed records on the salt flats. Wrapping your engine in foil isn't going to do much for a stock car that is running stoplight to stoplight.neagan wrote:You should take a look at an engine compartment of people that run the salt flats. EVERYTHING IS FOIL WRAPPED!!
So I check out the threads you have started in the past to see how smart you are, I figure you must be a genius if you feel you have the right to get on a forum and start calling people "dumber than a sack of hair." BTW, that insult reaks of intelligence. You started one thread asking what engine you had in your '93 'vert. Then, you started another thread that was basically the same as this one. So a couple weeks ago you can't answer this question, but now you are know it all that spends your time on the salt flats and taking turns at 100+ mph.neagan wrote:It's fools like you who... well never mind, you arn't worth my time, being that you're obviously dumber than a sack of hair.
