What is your tire pressure set at?4. How often do I need to clean my K&N air filter?
If you have not experienced a decrease in mileage or engine performance, chances are your filter is fine and does not yet need cleaning. To be more specific, the filter does not require cleaning if you can still see the wire screen on the entire air filter regardless of how dirty it may appear. When the screen is no longer visible some place on the filter, it is time to clean it. When used in normal paved road, street or highway conditions, our replacement air filters that fit in the factory air box should require cleaning every 50,000 miles and our large conical filters on an intake system should require cleaning every 100,000 miles. When used in dusty or off-road environments, our filters will require cleaning more often. We recommend that you visually inspect your filter once every 25,000 miles to determine if the screen is still visible.
Im checking to see if brembo brakes from a 350z/g35 fits my pathfinder, but it will be expensive and with custom fitment if possible.ottofalcon wrote:I have ceramic pads already, but it might try slotted rotors. Are there no bigger brake kits or something like that?
Well I just bought the air filter, I haven't cleaned it yet. The oil I change it about 4500-5000, that's when it usually starts getting a bit dirty. I always use Mobil1 EP 5-w30Towncivilian wrote:The color of the engine oil means nothing unless it's milky, which would indicate coolant present in the oil. How long is your typical oil change interval?
Don't clean your air filter too often, otherwise it will leave an oily film on your MAF sensor and potentially let more contaminants through. Filtration actually improves as it collects dirt. Follow K&N's recommendation:What is your tire pressure set at?4. How often do I need to clean my K&N air filter?
The spark plug change interval is 30k miles. Were they replaced around 120k? If not, replace them with 6 of NGK 6953 plugs. Run some Chevron Techron fuel system cleaner through one full tank of gas, too.
Never run anything higher than 87 octane in your QX4 again, the engine is designed to run on regular (87) octane and anything higher will not result in any gains whatsoever.
Ok, I'll check that out! Hey btw your from P.R. right?Alfredo24.pr wrote:Im checking to see if brembo brakes from a 350z/g35 fits my pathfinder, but it will be expensive and with custom fitment if possible.ottofalcon wrote:I have ceramic pads already, but it might try slotted rotors. Are there no bigger brake kits or something like that?
check for EBC 3GD Sport rotors on ebay for the front brakes. (they are drilled and slotted)
ottofalcon wrote:
The funny thing is that i bought it with 132k or so, and fuel economy was better around 180 miles on a tank. But the last couple of weeks have been horrible!
Exactly I use Distance Plus, Well my next oil change isnt coming up in a while but I'll follow your advice once it does.Towncivilian wrote:K&N filters are exactly the same as Mobil 1 filters except K&Ns have the welded nut at the bottom. Use M1 filters instead of K&N if you choose to use them again in the future.
By "Bosch" filters I assume you mean Bosch Distance+? Those are excellently built and can easily go 15k miles. If you're trying to clean out sludge, just use a conventional oil and do several 3,000 mile oil changes using Pennzoil Yellow Bottle (it contains a lot of detergents compared to other conventional oils) and Purolator PureONE filters, then switch to synthetic afterwards.
Compared to the OEM disc is there a big difference with the slotted?m0nkeyprince wrote:since your disks are new, just switch your pads to hawk LTS, theyll give you HPS type stopping power.
do NOT get drilled discs, they only reduce the structure strength and ive seen too many of them crack. The most you should go is slotted or dimpled like on the higher end EBC disks.
I myself have EBC slotted rotors with Hawk LTS pads and they stop like a dream. If those dont work, you probably have to bleed brakes (dont forget to bleed the Load sensing valve too)
and Town Civilian, its nice to see that you became a mod, I havnt been keeping up with nico n npora for a while so it was a surprise.
Yeah that's my best mileage, never been higher than 180, right now I'm at half a tank and I've driven exactly 73 miles!CanuckQx4 wrote: only get 180 miles to a tank and thats your BETTER mileage??
I get 250-260 a tank and I only city drive
wow but that must be because of the city traffic, because on highway trips I only take a bit more than 1/4 from San Juan to Mayaguez (a 105 mile trip)ottofalcon wrote:
