Obviously this is totally wrong. I just installed some Goodrich 2" extended (because of my lift) stainless steel brake lines and flushed the system out with racing brake fluid, can't remember which kind. The pedal is a lot more responsive and I doubt I will ever get any fade.iceman14n wrote:cross drilled or slotted rotors with ceramic pads is most you can do...
