Fifth Gear wrote:...I havent noticed anyone with a ka24de that has that much.
It would be a good idea to read and read and read...take a nap......and then read some more. You're gonna need to learn a lot in order to pull off 500+ to the wheels safely and reliably.
Fifth Gear wrote:I dont come to the site much...
For 500+ you need to visit the site _a_lot_ and read and read and read...plus other resources are out there with additional valuable information.
Fifth Gear wrote:Also i noticed that many people are running turbos on a stock block. I thought the compression ratio was to high.
The prevailing thought used to be that stock rods were good up to a certain hp threshold...some have had experiences that might indicate otherwise, even when running at low RPMs and good overall engine health and fanatical upkeep...
Proper tuning, piston face geometries, rod/stroke ratio, and squish band (as well as a myriad of other variables) can all be tweaked to run compression ratios varied over a great range and still deliver good power and torque. So I wouldn't worry too much at the outset about what the compression ratio is.
Good luck with your project...and most importantly, have fun.
