SeanDean wrote:So these will work on both intake and exhaust sides?
Yes, The intake and exhaust springs are the same.
One other thing I'm working on...
The stock Intake valves have a 7mm stem and the exhaust valves have a 8mm stem. 8mm is rather large and I believe is a result from the sodium filled design.
Manley can make any custom intake and exhaust valves, but they have a limited supply of exhaust blanks with an 8mm stem.
I don't know if anyone else has noticed or not, but the stock exhaust valves have an 8mm stem except for a taper to 7mm where the retainer attaches. I'd assume this was done to keep the retainers the same on the intake and exhaust valves and to reduce cost.
I need to find a replacement valve guide for the exhaust side that will allow me to run an exhaust valve with a 7mm stem. This will provide many more material choices for exhaust valves and I can still run the same retainer on the intake and exhaust valves. (And no, the outer diamter of the intake and exhaust guides are not the same, I'm not that lucky)
Also, Manley will have no problem taking their Titanium Honda Prelude retianers and boring them out to work with the 7mm stem size of the VH valves.
