defrag010 »
https://forums.nicoclub.com/defrag010-u35865.html
Fri May 25, 2007 9:40 pm
boy have i ever been down this road..
superhatch, one thing to watch out for is moving the retainer up.. I couldn't successfully move the retainer up anymore than about .050" before the edge of it would tough the rocker at closed position.Also, what kind of solid height does the inner spring have? I don't remember how tall the inner lip is on the guide boss, but that's one thing to watch out for too..
I'll have to dig out my measurements and notes and post them, but there are a bunch of valves and guides and springs that you can use on the VH with minimal work.. I think it's toyota 3TC guides that will knock in in place of VH exhaust guides, and just need to be shortened a little bit and reamed out to size.. and older prelude (forget engine code) intake valves can be shortened and re-grooved and used as 2mm oversize VH intake valves and i think there was a saturn dual spring setup with retainer that could be used on the vh too
If you want more spring, the easiest way to do it is to have your spring pads milled down. I measured them to be a little thicker than half an inch, so you could easily cut out .200" or so and run SBC springs.. That's what I'm doing on my toy heads -- cut down spring pads, SBC Z28 springs, stock VH retainers.
Modified by defrag010 at 1:01 AM 5/26/2007
