EdBwoyhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113I think I have a remote start system, but can't get it to work remotely. 2007 M45Thu Jan 23, 2020 11:14 pm
Postby
EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.htmlThu Jan 23, 2020 11:14 pm
2007 Infiniti M45.
I recently found out that my car has a remote start system...well, sort of. It doesn't really start the car remotely, and only seems to work with the key fob inside the car.
3 clicks of the lock button and the parking lights come on, and some relay under the dash will click. If the key fob is not in the car, it will show a KEY ID: NO warning
The video below will probably explain better.
Would anyone here happen to have a similar system and be able to tell me what I am not doing correctly in the startup sequence? Or is there a component that's missing?
Postby
Ilya »
https://forums.nicoclub.com/ilya-u159401.htmlFri Jan 24, 2020 8:35 am
I believe they had to sacrifice one of the OEM fobs inside the car for this functionality to work on the Y50s...do you know if there is a FOB that is always in the car?
Ditto for systems installed in the Rogues. A FOB has to be left in the vehicle. After awhile these systems start going wonky and the owners either disable them or remove it completely.
Postby
EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.htmlFri Jan 24, 2020 9:59 pm
Thanks for the pointers guys. I dropped the car off for the airbag recall, but will look at it closely once I pick it back up.
So what I gather is that the module is asking the car to start, but the car can't see the key so it doesn't actually start. Correct?
If so, its plausible that whatever sacrificial key was in there has a dead battery by now...although, I thought all they needed was a transponder in a box.
I'll update once I get the car back and get a chance to inspect it.
Postby
Ilya »
https://forums.nicoclub.com/ilya-u159401.htmlSat Jan 25, 2020 8:15 am
If it's a Fortin box, then you may just need to re-program it using their programmer and software to get the keyID back. If it's one of the 'OEM' starters that requires a sacrificial fob, then you may be correct. This is why I went Fortin...at first I didn't want to have a second fob on my keychain but I also didn't want to sacrifice a fob.
Postby
EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.htmlThu Feb 06, 2020 6:59 pm
Just an update that's not much of an update. I got the car back, but it's been parked since I got busy.
I started a new job in a different location & will be moving soon. The car will be left alone until I get a good opportunity to check the under-dash area to trace the wiring, take pictures & try some of the pointers I received.
