I spun a rod bearing now i need help NOW!
cunic
Car: 1993 240sx se
i got a stock 93 se and i spun a rod bearing.....im lookin just to replace the motor with another ka cause i damaged the block... can i use a ka from a newer model? will the exhuast all line up with no modifications. can i strip the sensors and other parts from my motor and put them on a newer one without mods? HELP SOMEONE
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
This information is alll available if you search.
cunic
Car: 1993 240sx se
is it? im brand new to this place
Hijacker
Car: '92 240sx Convertible
'94 F-150
It's obvious you haven't been formally introduced to our friend the Search Button
He says "Hi" and invites you to click on him at the top of the page. He gets very lonely and loves when people stop by to visit.
Seeing as how you've asked 2 fairly basic questions so far, I would highly recommend doing searches before you start asking questions. You'll get far less snarky responses.
And I'll do you a favor since you're new to this place. KA blocks are physically identical. The emissions are done different from S13 to S14, as is the fuel management. If you want simple and straight forward, just pull a KA from an S13. They're cheaper and plug and play. And given you mentioned doing a motor swap down the road, I assume you don't plan on sticking with whatever KA you toss in your car. Save your money on an S14 block and go with an older S13 block.
cunic
Car: 1993 240sx se
thanx... i deff did not know about the search button
Florida240sx
Welcome. Find another s13 dohc so there is no need to swap sensors or mani's.Keep your block and rebuild or part it out but keep the sensors for yourself.
