I smell like hawiian punch......
DALAZ_68
Car: 90' 240sx CA18det
hey gabby...would u say its worth rebuilding a T25 from a SR than one from a CA...cuz my CA stock turbo i can already hear it not as good as before...and ive got a turbo from a red top...looks good hardly any shaft play...but id like to rebuild it none the less...
BTW : the pumpkin head pic...FTW
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
ive seen SR turbos with no shaft play go pretty cheap. this was just cleaning, not rebuilding, but yeah I would opt ofr the SR over the CA turbo
DALAZ_68
ca18detgabby wrote:ive seen SR turbos with no shaft play go pretty cheap. this was just cleaning, not rebuilding, but yeah I would opt ofr the SR over the CA turbo
true...but id rather just rebuild it none the less so i have a much stronger turbo to fudge with...and the rebuild kit is around 78 bucks which isnt to bad
ca18detgabby
03 Infiniti G35
DALAZ_68 wrote:true...but id rather just rebuild it none the less so i have a much stronger turbo to fudge with...and the rebuild kit is around 78 bucks which isnt to bad
def the route to go. I have gotten into the nitty gritty of rebuilding built on a non-BB turbo seems pretty straight forward. there are a few nice write ups in the KA-T section.
Rin5
Car: 1990 240sx CA18DET, 1990 240sx SE fully auto (Daily)
damnit i was hoping for a story on hawaiian punch...all i saw was turbo and oil...now im craving for some HP
DALAZ_68
one more question...i finally got 2 tubro to redtop t25's, one blow, and the other miney inout play... i want to rebuild the blown turbo and i was able to get the rear housing off with some window cleaner and effort from god, (seized like a mother) and i looked into tryint ot remove the front housing....but **** were can i pick up a tool to remove that massive c clamp (snap ring) holding verything together...im going to dunk everything in some ATF as ur friend suggested.... help a homie CA guy out...
ca18detgabby
03 Infiniti G35
DALAZ_68 wrote:one more question...i finally got 2 tubro to redtop t25's, one blow, and the other miney inout play... i want to rebuild the blown turbo and i was able to get the rear housing off with some window cleaner and effort from god, (seized like a mother) and i looked into tryint ot remove the front housing....but **** were can i pick up a tool to remove that massive c clamp (snap ring) holding verything together...im going to dunk everything in some ATF as ur friend suggested.... help a homie CA guy out...
http://photo.platonoff.com/Aut...build/
those pliers look like something you can get at any ace hardware
DALAZ_68
**bow** thanks...i just dont wanna custom bend and make my needle nose pliers and have my pops shove a boot up my ***....
