I rode in the New and improved Altima Coupe CVT turbo..... noice!!!!
All things Altima Coupe.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
EVen at 4 PSI, this thing is still pretty freakin quick..... still a G37 killer by far!!!!
alt.coupe28
Car: 2008 Altima Coupe 3.5 CVT
details doc?! mmooore details!!! hahaa
Infantry1327
Car: 08' Nissan Altima Coupe SE
I didn't think Blake was going to re do his turbo. I hope he got the cooling under control and I can't wait for the meet.
marcelo929
Car: 3.5 SE Altima Coupe
Damn that was quick, I thought they would take longer to fix it. More detailllsss!!!!
Mr. Music
Car: 2008 Altima Coupe 2.5S CVT w/ Convenience Package
In the family: '02 S15 Spec R, '09 Rogue
Good to hear that the car is up and running good again.
marcelo929 wrote: More detailllsss!!!!
Infantry1327
I just talked to blake. He just got back off the aircraft carrier yesterday and he picked up his car. They have done alot of coolent work to hopefully keep the transmission running cool. So far so good, but they still have a little more work to put in and test it a bit more before he can bring it home.
So be patient and Blake will post up all the details when he gets a chance.
alt.coupe28
thanks for the update infantry. so far so good for the first cvt turbo coupe!
marlin29311
Car: 2008 Infiniti G35x
Im interested to hear more!
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
08altima35
Car: 08 Nissan Altima Coupe SE 3.5 6Spd Manny Artisan Turbo Dark Slate
4 lbs. is probably around a 30 to 40 whp gain max. It's not going to be a major difference and for the money spent could be beat with tune, headers, exhaust, intake, etc. Are they planning on running the boost up any? And, what was done to cool the cvt?
rjdmmfl1
08altima35 wrote:4 lbs. is probably around a 30 to 40 whp gain max. It's not going to be a major difference and for the money spent could be beat with tune, headers, exhaust, intake, etc. Are they planning on running the boost up any? And, what was done to cool the cvt?
I understand where you're coming from.. but again, even at 4 PSI (which is really low) this thing is still really quick. I've driven G37's and I am 100000% positive this thing will smoke a stock G37...
I'm actually on the phone with Blake right now.. he could do a much better job of explaining things than I could... and I'm sure he will do so later tonight!
Infantry1327
I talked to blake a little while ago, and things are running great. He put a dragster transmission cooler on it and the operation temp has dropped from 220 to 140. Once it has been fully tested and is sure the cvt can take it, he will up the boost.
Hope this anwers some of your questions. I am sure Blake will come on when he can and post more details
Hussain
Car: 08 Altima Coupe 3.5se CVT
so is it 220 degrees on a STOCK CVT or was it at 220 with the last turbo set-up? did he manage to keep it cooler then stock with the turbo on
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
Ok guys, 4 hours of traffic and I made it back from San Diego to my home in Camarillo.
The turbo is installed exactly the same as it was last time, however, this time we installed a massive transmission cooler with sensor and gauge in the car, in the upper portion of the STILLEN fascia. This lowered the operating temperature of the transmission between 120 (going 70 mph) and 180 (idle in traffic). The previous N/A operating temps of the transmission were between 180 and 220. Past 240 (which would occur under heavy boost in high outside temps), the transmission fluid started to boil and this is what ultimately caused the pressure sensor failure, that killed the first transmission.
So that is the big thing, protecting the transmission. Now for the boost. We installed a 4 psi spring in the wastegate purely for testing. If the transmission shows no signs of malfunction within our testing period, we will install a larger spring, and turn up the boost.
Now, for what Warner said. A common rule of thumb is for every psi of boost, it adds 10 hp. However, for you Warner, to call me on rules of thumb, would mean I would call you on your bishez for only pushing 7 psi out of your turbo, and claiming 100 hp increase. So you obviously know, the tune has just as much effect on the output power as the boost pressure does. At the 6 psi we ran the first time, we ran the stock computer. It made all the corrections, and ran the motor incredibly rich. Not the best for power. So, now we lower the boost to 4, however, Split Second has stepped in, and created a brand new piggy back type to the altima coupes all digital sensors/computers. So, in turn, with this computer, and the map programmed within, constitutes an almost identical increase in hp. Of course, a larger amount of boost has more potential to be harnessed into hp, without the proper tune however, it wont produce.
At any rate, my car is running good and strong. I will continue to post updates in this thread. Nice to see you guys still have an interest in the CVT Turbo
psi101101
Car: 2009 altima coupe 2.5s
where did u buy the turbo kit from??
adidas2go
I didn't buy the kit from anywhere. Speed Force prototyped and built this kit from scratch.. Speed Force Racing is selling it here: http://www.speedforceracing.co...o.php
Infantry1327
Blake you know if your boys at speed force want to put this system on another cvt for more accurate tests. You know who to call. 2 is always better than one.
Double the pleasure, double the fun.
I am glad your car is up and running, and don't forget to hit me up tomarro so I can take it out for a spin.
Hussain
did you guys see what they did the the hybrid race car? the hybrids are CVT's so i guess it's a CVT with 400+ HP and they say they are going to race it so they must have got it to take some abuse without over heating or anything.... wouldn't hurt to try and see what they did to it
uh-oh_8_coupe
Car: 2008 A/C Dark Slate 2.5
congrats dude, that's bad ***, i doubt theres a turbo or supercharger for the 2.5? i know the older alti's and se-r's had em, any chance for the 2.5ers?
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
So it sounds like SFR is close to finalizing the turbo!
Blake, will this transmission cooler be part of the turbo package and will this increase the price? I'm sure it will since it is requiring new components
adidas2go
This will not increase the price of the kit
psi101101
uh-oh_8_coupe wrote:congrats dude, that's bad ***, i doubt theres a turbo or supercharger for the 2.5? i know the older alti's and se-r's had em, any chance for the 2.5ers?
oh yeah, what about for the 2.5s?
alt.coupe28
nice!! glad to see your car is up and running again bro. i remember the first time we had a post of your cvt turbo. you were like the superhero of the a/cs! hahaa. but yeah keep us updated!
adidas2go
I will get some information and get back to you guys. Seriously, if a 2.5 in the socal area wants to pony up the money and do a turbo for the 2.5 community, Speed Force Racing could do a turbo for you guys too
mikegtr06
Car: 1995 180sx
how much money would said 2.5 have to fork up ?
adidas2go
I'm not sure, you would have to call Tim and ask. His number is on speed force racing's website
JDRosenberg07
Car: 08 Altima Coupe 2.5 6MT
+1 for the 2.5 turbo..
I know there are turbos out there that fit the QR25.. they just dont have a kit for our a/c..... yet
ItsEcko06
JDRosenberg07 wrote:+1 for the 2.5 turbo..
+2
me want but scared abt it breakin my car.... i love my a/c
Infantry1327
thats why blake is our test dummy. lol
JDRosenberg07
Infantry1327 wrote:thats why blake is our test dummy. lol
Or why you get the 6MT instead of the CVT
