Azrial wrote:no massive gain but if your timing is retarted a little bit you will gain some extra horse power if it is properly timed. Since your car is old like all of ours chances are it is probably out of time a little bit. Project car magazine gained 22whp and 15ft-lb of torque by bolting on an intake re-setting ignition timing and changing to a manual transmission. That is quite a bit of power for not a whole lot of money. I mean your already going to have to go manual if you plan on drifting anyhow.
PPle will probably flame me for this but:
I actually had MORE FUN at drift events when my KA was NA. I built my car with suspension and handling being a top priority and if I had to do it again, thats EXACTLY the way I would do it over again.
Handling is SO, SO, SO, much more important than power. I used to love beating up on big power guys and autox's or curvy back roads with a good handling car!!! So I didn't have as much tire smoke but my "tire bill" was a hell of a lot less too. You can still get massive angle with a LSD and a strong clutch tho.
Its AMAZING how a good set of tires, coilovers, LSD (!!), (adj) sway bars, replacment poly bushings, and a racing seat will make you look like a super star over the guys with loud BOV's and pipes that can't handle there car.
Starting off with good handling and low power will really teach you how to be a "momentum driver" and you'll be much better for it in the end.
GL........ Handling>Power IMHO.
