Summary
So ive checked everything on the IAC system and replaced what needed to be using the FSM. I also checked and adjusted the TPS, and it should be good now. nothing wrong with it.
I found this check list in the FSM about stuff that controls your idle. Heres what it looks like.
I checked off the things that are Obviously not effecting my idle.
Not the engine temp sensor, Just replaced it.
Not the air conditioning switch, Dont have ac.
Not the powersteering, that only works when you turn the wheels
Not the vehicle speed sensor, cars not moving.
-I see that it says the battery will effect it. Would a weak battery cuase the Ecu to make the AACV kick on? to charge the battery up? I know mine is a bit weak. But does it actually do that?
-The idle switch is the TPS sensor? NO? if it is i guess i could check it off.
-Im not to sure about the inhibitor switch since i dont have one anymore. My car is a Auto to manual conversion. I just connected the wires from the harness coming from the inhibitor swtich.
-Ignition switch... I dun know
carnk angle postion switch... I dont know... No code showing up for that.
