ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Thu Nov 01, 2007 11:53 am
does it blow out smoke when you are standing still or rolling to a stop?
During part load operation, your ECU uses the narrowband O2 sensor to stay close to stoich ratio... that's why you will see it dance back and forth.
During WOT, heavy load operation, your ECU will take the O2 sensor out of the loop and run a closed-loop control to purposely run your car run rich.
In anycase, if its smoking while you are stopped or slowing down, its possible that your turbo is blown out. T25s tend to go band esp with people pushing the boost.
