93coupe wrote:Did you find some Sportmax 002's? You will be fine without a roll. 205/50
He will definitely need at least a roll unless he doesn't want to lower it. And with that much travel, he'll still probably rub in hard corners.
You're DEFINITELY gonna need a fender roll, no way around it.
If you lower it, plan on adding some camber to those wheels, they stick out quite a bit without it
Do some research on what kind of tire you want. Many like the lower profile style, while others like the "meaty" look
There's plenty of threads in the 240sxgen section and the wheels/tires section with pictures to aid you in your decision.
