i need help!! my tach is crazy
motoman399
Car: 98' wrecked (RHD coming soon) 240
so my tachometer is going nuts. i took it all apart and couldnt find anything wrong with it. no burnt anything inside of it. does anyone know how to fix this.
i start my car and usually the tach will max out even if the car is at a perfect idle. sometimes if i hit the dash it will go back to normal. this is really pissing me off. here is a pic and i can get a video if someone wants. THANKS
motoman399
oh and this is a 98 s14 thanks
motoman399
nobody has any idea what this could be? come on its bugging the sh*t out of me
Razi
Car: Moo
Maybe you should take off your gauge cluster and see if the wiring is screwed up.
motoman399
i took the entire thing apart. cant find any wiring messed up or any burnt diods or anything out of the ordinary
fun240
Car: 95' S14, 91' NX1600
Whys your CEL on?
Have you checked it?
AZ89two4Tsx
Woah, you really shouldn't rev your engine that high, can't be good at all.
Have you checked the harness and connections?
xX RB Xx
Car: SE3P, FC3S, FC3C.
it looks like someone is hitting vtec
hotcakes0007
Car: 2002 Lexus Is300
Its going to be the wire under ur transmission its the rpm wire i dont have a pic but m car was doing the same thing and i fixed it.
ThuG LyFe
Car: 95 S14
i think your problem is you have a F20C under the hood and you don't know about it.
jk of course...good luck with the problem though, maybe just buy a new cluster or borrow one from someone to see if it works.
Philipio
Car: 96 240sx, 96 Miata
ThuG LyFe wrote:jk of course...good luck with the problem though, maybe just buy a new cluster or borrow one from someone to see if it works.
I bought a new cluster and it only made things even more confusing. My original tach was doing the exact same thing as the original poster's. The new tach I got is extremely sluggish and only seems to rev to around 3k RPM max (the tach, not the engine). I haven't had a working tach in SO long.
Elaborate on the "RPM wire under the transmission?" I thought there was just a speed sensor.
motoman399
fukin240 wrote:Whys your CEL on?
my cel is on cause it used to be an automatic and is now a 5 speed and i dont have transmission sensors hooked up.
AZ89two4Tsx wrote:Woah, you really shouldn't rev your engine that high, can't be good at all.
yes everything appears to be perfect
hotcakes0007 wrote:Its going to be the wire under ur transmission its the rpm wire i dont have a pic but m car was doing the same thing and i fixed it.
i dont think there is an rpm wire on the transmission. there is a speed wire but rpm goes through the cam and crank sensors if im not mistaken
ThuG LyFe wrote:i think your problem is you have a F20C under the hood and you don't know about it.
i live in a small town... i have the only 97-98 240 for at least 300 miles lol
Philipio wrote:I bought a new cluster and it only made things even more confusing. My original tach was doing the exact same thing as the original poster's. The new tach I got is extremely sluggish and only seems to rev to around 3k RPM max (the tach, not the engine). I haven't had a working tach in SO long.
so your new tach was it stock? i hope that my computer isnt screwed
motoman399
oh and this problem just happened randomly. i didnt do anything new to the car. so i know i didnt do it myself...... at least i dont think
Philipio
motoman399 wrote:so your new tach was it stock? i hope that my computer isnt screwed
It was a cluster that came right out of another '96, they said they could guarantee it was working properly when I bought it.
Kouki_Projekt
anyone know what the problem was? cause unfortunately my rpm tach is doin the same thing out of random... -_-
motoman399
it turned out to be the motor in my tach. i used one from a maxima around the same year and soldered it in there. it worked for a little while but i didnt get the needle in there right and it was really slow moving. just buy a new cluster and save hours of headaches
Philipio
motoman399 wrote:just buy a new cluster and save hours of headaches
Yes, this is exactly what I said, haha.
If you're having tach problems: GET A NEW TACH. Problem solved. Tachs go out all the time.
Ironically, my 107k mile original tach died and the 197k mile tach I got to replace it works great.
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
i killed my tach doing light and now i need a new one simple right
Cerevo
Car: 97 240 base
Man, this sucks. Mine is doing the exact same thing. Sometimes I can hit the dash or turn the car off while rolling then "bump" start it and its fine (weird I know) but lately it just wants to read abut 3000 rpms too high.
motoman399
just get a new cluster. it will fix the problem. you can solder in a new tach motor, but the whole needle deal is weird. it has to be in a certain position for it to function properly. just get a new cluster and it will fix your problem.
Cerevo
Car: 97 240 base
Uhgg, how big of a deal is it to take the cluster out?
motoman399
on s14 its easy.
1) take off top of steering column cover [4 screws]
2) lower column all the way
3) take out cluster bezel [2 screws and unplug dimmer switch and cruise control if you have it]
4) take out cluster [3 screws (on zenki its 4 plugs and on kouki its 3 plugs on the back)]
super easy. all Phillips screws
Cerevo
Car: 97 240 base
Oh awesome, thank you!
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
S13 is the same..
motoman399
almost, you have to drop the steering column, and there is more switches that need to be unplugged that are a tad harder to do. but more or less the same. yep.
zenkistic
Car: 96 240 SE
motoman, do you have any of that slots that the bulbs go in for the cluster? the brown ones for CEL/oil etc?
motoman399
are you asking if i have spare bulb's and sockets? i do have spares. send me a pm with pics of what you need and ill hook you up cheap.
wingFeather
Car: Current: 05 G35 Coupe
Previous: M35, M35 Sport, cube, J30, s13 sr20det, s13 rb20det, s14 zenki
motoman399 wrote:just get a new cluster. it will fix the problem. you can solder in a new tach motor, but the whole needle deal is weird. it has to be in a certain position for it to function properly. just get a new cluster and it will fix your problem.
I had good luck taking the entire tach assembly (minus the face) out of a Sentra & putting it into my S14. No need to solder.
motoman399
what year sentra did you use? all the ones i looked at had the wrong bolt pattern and the tach motor was different too. mine was a kouki cluster by the way. what was yours?
Cerevo
Car: 97 240 base
interested as well, mine is a 97 with black gauges
