i need help!! my tach is crazy
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
motoman399 wrote:almost, you have to drop the steering column, and there is more switches that need to be unplugged that are a tad harder to do. but more or less the same. yep.
motoman399 wrote: 2) lower column all the way
motoman399
Car: 98' wrecked (RHD coming soon) 240
^^ except on the s14 you tilt the column down. on the s13 you unbolt the column and let it hang. s14 is much more user friendly. i can pull the cluster in about 3 minutes lol
