babowc »
https://forums.nicoclub.com/babowc-u21423.html
Sun Aug 27, 2006 11:01 am
dude.. unless you MASHED the brake pedal, the wheels will NOT lock up.
what is your definition of GOOD TIRES?just good tread left on the tires?
you dont need to upgrade to bigger brakes if you're not planning on autocrossing or doing major brake-gas-brake-gas-brake type motorsport, which all i can think if would be autox.
i ran with stock brakes and upgraded pads until i sold the car, drove very "spirited", didnt give out a single stop, need i mention i had decent to good tires.
right now, i have a z32 front brake setup with 18x8.5 wheels all around and it stops worse than the stock brakes with upgraded pads did, only because my tires are looking like slicks.
moral of story, tires > brakes.bigger brakes = less brake fade.more pistons in a caliper = harder clamping force, obviously, heavier cars will need harder clamping force due to physics.however, on the other hand, 240sx weighs at most 2800lbs with driver.that is light.
i just cant justify the overkill of brakes on the 240sx unless you're planning some major autox.
*note* i bought my car with the z32 brake setup with the wheels, so dont give me crap about that.*
