Ramius83 wrote:Here is another side note. Are the shavings magnetic? This will tell us if they are of steel or aluminum origin. (Magnetic is non-magnetic, steel is magnetic).
Great idea Ramius. Thank you. I took a magnet out there. The shavings are aluminum then. They don't stick to the the magnet. The magnet sticks to the fenders, the cam itself, the outside of the head, the cam wheel...
The magnet doesn't stick to the air intake, the CAS bracket, the shavings, etc...
Alex.. You are wicked smart... A little over my head.. but I think I get what you are saying. So, it's not oil pressure, or an oil seal or anything like that.
I think you are wrong on the CAS... I could be wrong.. I usually am... but here is why I think it's not the CAS. When Justin came over the other day we swapped his CAS onto my engine. His CAS works perfectly. On my car the struggling sounds didn't change from his CAS to mine. I know that I need a new CAS... I have one in the mail now in fact, because mine was hard to rotate, but not so hard to cause all the problems itself.
Anyhow.. just the fact that we put a known perfectly working CAS on my engine and it didn't help leads me to believe it's something different.
Question... What's the end of the Camshaft made of... Aluminum or Steel?
Here's a pic I found of an RB20 cam. The end has four screw holes.
Could the shaving be coming of the end of the cam itself? Might that be the source? If so... what's it rubbing against to cause that?
It shouldn't be the cam wheel itself rubbing on the end of the cam like I was sort of thinking... it couldn't be because they are attached and turning at the same speed.
The head itself is steel right? Not aluminum?
