Clawhammer wrote:According to the link duff posted:
"AAC/IAC: The AAC valve (Auxiliary Air Controller) takes in the air ratio and puts it through the computer keeping a tab on how much air is entering the intake. Mostly it is the ECU's main idle control system and can deff control the A/F ratio. Sometimes this sensor can get clogged with carbon and cannot get a good reading. To get a new one you’re looking at $170-$299 (ouch) so cleaning it might be a more cost effective way to attack this problem. I have a 94 Black Top so mine is located under the fuel rail towards the firewall. It does take some work to get at it but some Carb Cleaner and a fine brush should do the trick.*One thing to remember!There is a gasket that needs to be replaced once you take off the valve itself. "
Whoa whoa whoa.
Hold on a minute. The MAFS is what meters air entering the engine. That being said, I dont know as much about the S14 SRs, there may be some kind of some sort of fuel control system after the throttle body, though I doubt it.
The truth of the mater is, even if it does have some sort of system like that, if would only effect the engine at idle and part throttle. The engine runs in open loop mode, using preset injector pulse widths, it ignores almost every sensor.
Have you checked for ECU codes?
