since your haze is pretty bad, i will advise you start with 600 grit. dont use lower than 400. then use 1000, then 1500 until it looks very dull. It should clear up when you wash the headlights, then dry and turn dull again. This is what you want then you use polish, I used aluminum polish, worked fine for me. use a buffer if you can. make sure you tape around your lights also.zerothread?id=234804 nice mileage by the way!AceFox wrote:Thanks, and I'm glad you like the car. How do I clean the headlights? The yellow haze is kinda nasty
driven_ wrote:Oh, i know which one you bought (off craigslist. heh.)
i was told it has *light* rust.
but hey! welcome,mine prob, has more rust!
midwest cars FTL.
YuNg1’s_240sx wrote:since your haze is pretty bad, i will advise you start with 600 grit. dont use lower than 400. then use 1000, then 1500 until it looks very dull. It should clear up when you wash the headlights, then dry and turn dull again. This is what you want then you use polish, I used aluminum polish, worked fine for me. use a buffer if you can. make sure you tape around your lights also.zerothread?id=234804 nice mileage by the way!
