I'm New Here And I have A Simple Question Thread, (No Flaming Allowed)
needfaster240
Car: 90' 240 sx
needfaster240 wrote:ok im back and alittle ticked..... papasmurf.... Q? im driving to down town atlanta the other night and notice when i let off the accellerator it has a stumble when you get back into the throttle. no big deal it comes and goes. get off the interstate in down town on a hill. it very difficult to negotiate when you give it gas and it tries to die. i stall it and wont restart. this is a 50-60 mile drive. get the little bashtard towed home. (yeah thats a tow bill you dont want!!!) go out there sunday morning to see what the deal is and started right up. pouring black smoke. my question what can cause it to load up. this is a KAe by the way. i unplugged the mafs to see if it would start it did not. now ifyou unplg it it just goes to default. what else can cause it. injector sticking, inj driver going out (ecu)??????? im lost. looked for simular conversation but no luck.
Modified by needfaster240 at 5:31 PM 12/19/2008
papasmurf its doing it again. except before it shuts down, at red lights and stops, it idles at 1200 rpms somtime 1500. luckiley it hasnt broke down at the red lights. my question to you and anyone else who would have the answer.....what controls the idle speed and fuel. it ran for a month and no problem......im bent??????? everything checks out fine. oh yeah i cant find the ohm and voltage specs for the maf can you hook a brother up???
PapaSmurf2k3
Site Admin
Hmmm... my MAF put out about 1 volt at idle, and about .5 when the car was off, but the on key was on. I doubt it is your maf though. Have you tried seafoaming the car? Or cleaning the idle air control valve? (That is what controls the air going into the engine at idle). Will it continue to run if you give it gas? Have you checked for any vacuum leaks?
Do you have an FSM? The link for them is in my sig if you don't.
idriftnsj
Car: 90s13
QUOTE=needfaster240]
papasmurf its doing it again. except before it shuts down, at red lights and stops, it idles at 1200 rpms somtime 1500. luckiley it hasnt broke down at the red lights. my question to you and anyone else who would have the answer.....what controls the idle speed and fuel. it ran for a month and no problem......im bent??????? everything checks out fine. oh yeah i cant find the ohm and voltage specs for the maf can you hook a brother up??? [/QUOTE]first replace the air temp sensor the small one on the side of the airbox it controls timing n fuel trim when it goe bad they go out of wack then replace the plugs n o2 sensor they should b fouled from all the fuel then c what happen.my car did the same thing
needfaster240
Car: 90' 240 sx
PapaSmurf2k3 wrote:Hmmm... my MAF put out about 1 volt at idle, and about .5 when the car was off, but the on key was on. I doubt it is your maf though. Have you tried seafoaming the car? Or cleaning the idle air control valve? (That is what controls the air going into the engine at idle). Will it continue to run if you give it gas? Have you checked for any vacuum leaks?
ok newb q? what is fsm??? and it is doing the exact same thing it was i just noticed the idle problem. i think they're related. ones causing the other. it hard to diagnose because i have to drive it for a while and im scared it leave me on the side of the road. ill try the sea foam. i picked some up at wally world for my motorcycle.(its been sitting for a couple years.)
PapaSmurf2k3
Site Admin
FSM= Factory Service Manual... the only link in my sig.
If you seafoam the car, you should also replace the spark plugs and O2 Sensor AFTER performing the seafoam.
alfsnissan
Car: 1995 Nissan 240SX
Pap! If I upgrade the front brakes to z32(just the front) do I need to change the BMC to a z32? Thanks.
PapaSmurf2k3
Site Admin
Nope, I've been running Z32 fronts, stock rears, and stock BMC for years now.
Snapples19
Car: 1993 240sx
Hey I just bought 300zx rear calipers but dont have the front ones. Would it matter if I put the 300zx rear calipers on and left the front ones stock?
alfsnissan
Snapples19 wrote:Hey I just bought 300zx rear calipers but dont have the front ones. Would it matter if I put the 300zx rear calipers on and left the front ones stock?
You have all the parts for the swap on the rear(e brakes and all)? If so you can do the swap but keep in mind that most of you stopping power is in the front. But no, it'll not hurt anything to do the swap on just the rear.
Adam
PapaSmurf2k3
Site Admin
it MIGHT make the car rear-brake bias. Meaning you might lock up the rears before the fronts if you do that.
Snapples19
Car: 1993 240sx
Thnx i appreaciate it!
2g00d4u
Im installing a new head unit in my s13 HB but the shifter (auto) is in the way...
Is it okay (or even possible) to move the shift down so that I can have room for the installation?
PapaSmurf2k3
Site Admin
Yeah, if it wont let you, turn the car on, throw the shifter all the way down, shut the car off, and put the parking brake on.
lagspikeftw
Car: 1999 Pontiac Trans Am
I have a chance at getting a set of 4 tires and wheels for $50 today. the tires are 225/60/15, though I am not sure of the offset/width of the rim. If these tires were on my stock se rims, Would they rub all around, or only in the front? (93 hatch)
needfaster240
Car: 90' 240 sx
PapaSmurf2k3 wrote:If you seafoam the car, you should also replace the spark plugs and O2 Sensor AFTER performing the seafoam.
what is the best way to inroduce the seafoam???? im thinking thru a vacum port in the tb.???? and remove the iac tooth brush that bishhhh?
PapaSmurf2k3
Site Admin
lagspikeftw wrote:I have a chance at getting a set of 4 tires and wheels for $50 today. the tires are 225/60/15, though I am not sure of the offset/width of the rim. If these tires were on my stock se rims, Would they rub all around, or only in the front? (93 hatch)
That depends on the offset, but hey, $50... you can't go wrong. You can turn them around and sell them for more than that, or even get more for the scrap alluminum.
225/60/15 is going to be taller than your stock tire too, so your speedo may be off a little bit.
I always run it through the brake booster line. There are directions on the back of it, but basically, I put about 1/2 of a can through the brake booster, shut the car off, and leave it for about 10 mins. I come back, flog the **** out of it out on the road (with the brake booster line hooked back up obviously. Also make sure you are in a semi-low traffic area, you don't want to smoke out a road and cause an accident), and then drive for another day or so before I replace the plugs and O2 sensor. The other half of the bottle, either run it in your gasoline, or save it for another day/car.
IACV, yeah, remove it, carb cleaner it, toothbrush it, however you can manage it. Look for vacuum leaks while you are back there.
Pdawg
Car: Grand Prix GTP - 240sx envy
This is a good thread..
Is it worth it to buy a 240 for cheap and fix it up instead of paying 4G or does it just depend?
PapaSmurf2k3
Site Admin
buy it for cheap and fix it up. It'll keep you off the street, out of trouble, and will give you valuable knowledge that you can use throughout your life (or when the car breaks down in the future hah).
Pdawg
That's the way i was thinking. Is $1000 a good price for a paint job? Also is there any thing to look for in partic. besides rust? Thank you brother
PapaSmurf2k3
Site Admin
$1000 is a good price for a good paint job. Deals can be found, but sometimes you can pay $1000 for a paint job that will get you... well, a bad paint job.
You should also do a compression check on the engine (should read higher than 149psi). Check the oil, make sure it isn't "Milky" (meaning blown head gasket). Check to see if the motor rocks back and forth a lot while you crank it (requires a friend... indicates blown motor mounts).Also, bald rear tires (or 1 bald rear tire) indicates its had the crap beaten out of it. If it is a hatchback and has a spoiler, chances are it has rust underneath it. Look in the spare tire well for copious amounts of water.
Pdawg
Thank you im sure ill have more questions in the future. Ill probably get into one when it warms up if i dont change my mind. I just dont want to get in over my head and realize the car needs more than i can provide since they are old.
PapaSmurf2k3
Site Admin
They are pretty simple cars. Stock parts should be pretty easy to come by because everyone likes to upgrade...
megaderk
Car: '90 240sx coupe
is it legal to drive around without a front bumper or hood?
Pdawg
Depends on your state I know where im from no hoods is illegal.
PapaSmurf2k3
Site Admin
It might depend on the state, but as long as its just the bumper cover, and not the bumper support, then yes. No hood should also be legal.
megaderk
im in illinois
PapaSmurf2k3
Site Admin
I'm in Mississippi.
conrad_s13.5
Car: 92 240sx hatch
PapaSmurf2k3 wrote:I'm in Mississippi.
im in missouri....lol
lagspikeftw
the 6 bolt j30 VLSD should bolt right up to the s13 right? Only thing to change would be the rear diff cover?
Millertime80
Car: Hatch S13, SR20det
How do you PM? haha I've looked all over the place and can't find it.
Thank you
