nissanfanatic wrote:For future reference, 400whp doesn't requrie you to upgrade the valvetrain, raise the displacement, get a new crank, or a stand-alone. Look at klattr1. He's making over 400whp on a JWT ECU tune. **** anthony was prolly making damn close to 400whp on just a SAFC.
Ah I see. I guess I was listing the mods for quite a bit more power then
Don't you have to upgrade the injectors?
nissanfanatic wrote:So, uh, point being, piston swap(8.5:1), machine work, ECU tune with 600+cc injectors, Z32 MAFS, and a decently sized turbo will net you about 400whp.
I see, I didn't realize that the KA had such potential. If that's the case then why in the hell are people swapping in SRs?
nissanfanatic wrote:Stock transmission can hold up pretty well as long as you don't launch the hell out of it with slicks all the time. Don't think your camaros stock drivetrain is gonna hold up any better tho. I watched a stock Ford 9" rear-end with 4.56 gears pop(main caps blew out) under less than 400ft-lbs of torque. Well actually I watched three of them pop on the same car.
Yeah, I've seen those too. They usually pick the WRONG 9".
Florida240sx wrote:Yea I could spend 1200 on a rebuild, and then 4k turbo ki with exhaust and have 400rwhp all day long.You guys aren't helping much the poll is 50/50/0.
ANd how long will it last?
