i'm finally KA-T!!
a240sxpinoy
Car: Nissan sil40
so after a long time awaiting, here are some pics of my turbo kit.
custom sr manifold to fit the kasr t25sr 370cc injectorsaem wideband afr gaugeside mount sr intercoolerjgs oil draincustom ss oil feed -3anemance tunemegan adjustable fprwalbro 255 fuel pumpstock sr dp (bolted right on)stock sr elbow
so with the stock intercooler piping, i messed up and cut next to the bend. thats why there is two blue silicone couplings! lol
the stock sr manifold was cut at the flanges and then welded the stock ka24de flanges. my friend welds for a living and said he knows how to work with cast iron...
ill post more pics later but so far is been about 500 miles.
afrs on idle is between 13-16 (i need to find out why it fluctuates so much)crusing afrs are between 14-15and when i am boosting its around 11-12
480sx
Car: 1996 Pearl White 240sx
Nice bud, i love that manifold.
So how much did you spend in total?
Your emance tune seems to be working out O.K. Do you have a good o2 sensor? That *could* be why your idle afrs are so bouncy idk.
nismo_power
Car: 91 240sx fastback se
how much boost are you doing???i got almost the same setup and was planning on doing 10psi but kinda scared of it blowing up???
kouki_hmongster
Car: Want 97 kouki
Looks bad@ss bro! i'm still trippin about the manifold, never thought it would work and espcially bolt on to sr dp.
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
That side mount piping is the nuts. I can't tell from the pics but that vent tube coming out of the valve cover needs to be routed back into the air stream. Preferrably after the maf and before the turbo. Your car will idle weird if not.
1mansho
nice build! where did you get the coupler connected from the intake pipe to the throttle body and the 90 degree elbow from your hot pipe to the turbo?
shimizu_17
cool budget setup. Id like to know the complete price list of your parts if you don't mind sharing.
abc123omg
Car: '93 240sx KA-T
glad to see ur up and running man, an di se eyou got that fpr. make sure its set at 1:1 and whats your idle?
a240sxpinoy
Car: Nissan sil40
D-UNIT wrote:That side mount piping is the nuts. I can't tell from the pics but that vent tube coming out of the valve cover needs to be routed back into the air stream. Preferrably after the maf and before the turbo. Your car will idle weird if not.
i know im working on it, there is a extra spot on the stock sr intake piping that im planning to route it back into there. ya the side mount piping would have looked cleaner if i didnt mess up.
nismo_power wrote:how much boost are you doing???i got almost the same setup and was planning on doing 10psi but kinda scared of it blowing up???
im just boosting stock right now 7psi. im scared too of blowing it up, its my daily and im checking everything constantly.
kouki_hmongster wrote:Looks bad@ss bro! i'm still trippin about the manifold, never thought it would work and espcially bolt on to sr dp.
i know!! im going to post pic of how it looks. lol i was suprised when it matched up. lol
1mansho wrote:nice build! where did you get the coupler connected from the intake pipe to the throttle body and the 90 degree elbow from your hot pipe to the turbo?
ok the one that connects to the throttle body has two different couplings on it, and one straight adaptor from homedepot. i just angled it a little here and there to fit. lol
shimizu_17 wrote:cool budget setup. Id like to know the complete price list of your parts if you don't mind sharing.
i've been parting piece by piece for a very long time. lol maybe a year or two worth.
t25-$50370cc-$50aem wideband-$220megan fpr-$75sr intake piping-$50sr stock dp-$40sr intercooler piping-$40sr sidemount-$20walbro 255-$100emance tune-$150 (went to SD to drop it off and pick it up)manifold-free (cause my friend and i worked on it)90* coupling from CXracing-$1524 inches of straight coupling-$40etc..(gaskets, bolts, nuts,)-about $100
grand total about $950
red_rain
Car: 91 ka-t n 300zx
love it....keep it up yo....
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
looks like a factory boosted ka...
sommmatt
Car: 1989 Nissan 240SX
I'm fairly sure if you got rid of the blue couplers, on first glance, someone would think it's supposed to be that way. props.
a240sxpinoy
Car: Nissan sil40
thanks! ya im planning on getting rid of the blue couplings.
Here's a picture with the stock heat shield. it not bolted cause i need to get bolts to bolt it on.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
im curious, when do you hit full boost?
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
looks nice!
i'll come by and check it out asoon as i get my car running.
hows tha E-Mance ECU treating you?
BoostFab
Car: S13cp, S13fb, S14z
a240sxpinoy wrote:the stock sr manifold was cut at the flanges and then welded the stock ka24de flanges. my friend welds for a living and said he knows how to work with cast iron...
that's a pretty neat idea, i never thought about that. looks like the runners line up perfectly.
a240sxpinoy
Car: Nissan sil40
ya they line up ok. i needed to even the inside out a little..i took pictures of that too.
i hit full boost pretty quick. its my first turbo car so ya. i know i hit full boost faster than my dad's stock 1993 Mr2 turbo.
ill try to get some vids.
ill post more pictures of the manifold asap.
slipknot555_666_69
Car: 97 nissan 240sx
how much hp is that baby running?
esahuque
Car: 95 240sx KA-T, 04 frontier
slipknot555_666_69 wrote:how much hp is that baby running?
with a stock sr setup, I going to guess about 220. thats what my friend put down with about the same setup on his ka
slipknot555_666_69
not to bad though i like how you customized that header and came out so cheep turboing a ka
xrproto07
Car: 96 S14 zenki
Very cool and budget friendly setup you got there bro, spools pretty quick i bet, i love your set-up!
a240sxpinoy
Car: Nissan sil40
thanks guys! im planning to dyno it once i get the little bugs worked out.
red ka-t
Car: s13
So how do you like your car now that its boosted? Do you have any kills yet? Are you going to turn your boost up? Jst wait till you boost that baby to 12psi your going to love it.
a240sxpinoy
Car: Nissan sil40
yes i like it a lot. very fun car to drive now. and good in gas!
its weird though, before i was turbo a lot of cars picked on me, having the silvia front end and what not, but now ever since i turboed, no one has? really weird though, i run the circulated bov and stock side mount so nothing that stands out. lol
S13FX
Car: '69 l20b Dimeski :)
Kick *** idea with the SR mani. Iv been telling people forever that the SR mani works perfectly with the DE flanges welded on, and I'm glad someone finally did it.
Plus using that bottom mount mani has room for a bigger T25 flanged turbo in the future depending on what your power goals are, but since you mentioned this is your first turbo car just gotta say good job and youl get power hungry soon hehe.
Happy Boostin.
WDRacing
Lovin the setup man
s14derrick
Car: 1995 nissan 240sx
its almost all sr parts like a sr24det lol.i wonder what power compared to an sr with the walbro pump and a tune would be
40daws
That is so innovative with the manifold ! Kudos to you sir,kudos. You have inspired me to look at going KA-T again.
a240sxpinoy
Car: Nissan sil40
update>>> still good and runnin! 15,000+ miles!
neverlift
nice update!SO any issues along the way? I had plenty of stumbles in the past, but keep on truckin
