numbnuts240 wrote:everybody knows...the bird is the word...
Bird, bird, birrrd, ba-birrrds the
numbnuts240 wrote:how the hell do i make reptar BIGGER??!?!!?!?!?!1!?1?1!?1?!?1
If you have reptar saved on your computer somewhere, go find him in your files and right click on him. The menu should say either "edit" or "open with" somewhere in there. Click on either of the two.
If you clicked on "edit", then you will open the picture automatically with MS Paint.
If you clicked on "open with", then you must choose the "Paint" program to open the picture with first.
First you need to set the attributes to make sure your picture has no white background in it. In "Paint", go to "Image" and click on that. In the "image" menu, lick on "Attributes". Then type in the number 1 in height, 1 in width and hit return each time and close it. Once you did that, go back in the "Paint" menu to "Image" and click that again. In the "image" menu, click on "Stretch/Skew" and play around with the horizontal and vertical, and make sure the two numbers are the same.
