aleph1 »
https://forums.nicoclub.com/aleph1-u177.html
Fri Oct 24, 2003 7:25 am
You have 5Gs, I can GUARATEE you that if you put said money into a KAT, it will with go MUCH further than an SR. SR with normal bolt on mods done at swap time (roughly 5gs all together) yields something like 180-220whp.
You get a turbo setup for a KAT, and since you have 5gs you can get a nice turbo setup with all the normal aftermarket turbo goodies, with a good fuel system going as well as some Ross pistons, it will boost 10psi, at least, reliably. At this boost, the engine output will likely be around 250-280whp. As a bonus, all maintaince parts at local shops, cheap, and if you DO happen to blow engines (as most SR owners will claim), they are cheap too.
KA is just a strong as SR, ka has forged rods, piston oil squiters (found usually in turbo cars to cool down the pistons from the high combustion temps), the weak point are the pistons, which I believe is also a weak point of the SR (also rocker arms). Dont quote me on that though.
Listen, the SR isnt any better than the KA other than it comes stock turbocharged. You are missing the whole point of the SR, it was never meant to be imported and swapped here for 3000 dollars for an extra 50hp. The japanese got it stock, so they worked with what they got. We got the KA, so I say, we should work with what we already have, your money WILL go further.
NOTE: Usually its only the SR owners who badmouth the KA, buying into SuperStreet saying that its a truck engine and non turbo so it MUST suck...Once I turbo my KA (early next year, finally) I will personally challenge any SR owner that thinks the KA sucks.
