I having major probs please help....someone!!!
AllDayDrifter
Car: 1991 240sx hatch
I have a 1991 240sx with a s13 blacktop swap, and i cant get it to start.......i sent my harness off and got it double checked and its perfectly good, my CAS and ignitors good and so are all my coilpacks are good. Im getting spark and fuel to every cylinder but its not starting..it just cranks and turns over...Just last week i sent the harness off and got it double check and it good then when i got it back and put it in, when i put the key in the ON position it doesnt prime the motor it just runs the whole time..i dont know whats wrong...can someone please help me!!! I really need to get this car running because i wrecked my Acura RSX-S last year causing me to be disabled...and everyone sayes i cant drift and i really want to prove them wrong...please can i get some help ^_^ and you wana c the type S look at my profile
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
check timing and spark timing, if its not perfect, or very close to it, the car wont run, check compression, with out it nothing works, hope this helps, good luck, and welcome to Nico.
CoupedUp
Car: 1993 Coupe
Make sure your fuel lines arent reversed.
AllDayDrifter
i'm begining to think my ecu's messed up...
