i have a problem with my motor PLEASE HELP?
sloweighty
Car: sileighty
Hey there , i have a ka24e and i need some help because whenever i start up my motor it sounds fine but when i start to drive it, it would sound fine too. But when i stop and just sit there, i would hear this knocking noise but when i give it gas it would stop the noise. The noise is coming from the inside of the valve cover and i know my piston and rods are fine, but i have no idea what it is so i thought since almost everyone here used to own or had some experiences with one, i was hoping you guys or gals can help me. One more thing, the car can still drive like normal and should i just park the car until i get it fix or is it ok to keep on driving it. Any help would be great
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Try searching for problems related to the timing chain, it is a very common issue with the KA, though I'm not sure if the Es are effected like the DEs. Ive never owned an E so I will let someone else chime in with better advice. You could try searching, Im sure you will find something.
sloweighty
Car: sileighty
i have search around and i am still searching so if anyone has any idea of what it could be please help
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
If it isn't a timing chain guard issue, it might be a bad lifter. My old Probe used to do the same thing.
sloweighty
Car: sileighty
is it hard to fix the problem and can i just get the lifter from a used head
sloweighty
Car: sileighty
bump
sloweighty
Car: sileighty
please
justy90240sx
Car: 90 240sx se, 95 240sx, 92 300zx
i would pull the valve cover off, just to be sure its not the cam chain. u should no right away. i did only who i bought the car from ran it until it jumped time and wouldnt run. i was lucky thought it stoped running before it jumped time enough to bend a valve
sloweighty
Car: sileighty
but the knocking only comes on when the car is warm and i haven't heard it for a couple of days now and i know my fan clutch is not working right and my friend told me that my alternator bearings were getting dry and he told me to replace them but that was like a month ago and i haven't got the chance to replace them yet so could it be the cause of one of these items i listed, because i have no clue rightnow so any help would be get, thanks
sloweighty
Car: sileighty
please help
sloweighty
Car: sileighty
well yesterday i went to this shop that have been open for over 40 years and the owner, which is still alive, he told me to just use this oil called Marvel Mystery. He told me to just substitute one quart of oil for the marvel mystery and it should make the problem go away. The reason why is because ka24e have hydraulic lifters, it needed to be bleed so he told me i should just use marvel mystery and it should clean out the lifters and make everything work again. So if you anyone has ever use this then please let me know how well it work.
My RB25
Car: 1990 Nissan 240SX SE
Btw the E is affected the same way the DE is with the timing chain. If it was your timing chain you would hear a nasty rattle on start up. I've also heard the lifters on the E (Not to sure bout the DE) are common for creating clicking or knocking noises. I'm pretty sure there's a how-to somewhere around here on how to bleed em.
And you alternator bearing...how'd your friend determine they were dry? Unless its making a nasty grinding or humming noise (easy to pin point with a stethoscope) I would leave it alone. As far as I know all, if not most alternator bearings are self contained and require you to replace the alternator. And if your not mechanically inclined, I don't suggest ripping apart the alternator yourself. Not to mention the cost of a R/R would prolly be more than just replacing the whole alternator.
skrappy
Car: BNRPS13
Ima go ahead and ask this. Have you checked your oil level lately.
sloweighty
Car: sileighty
i knew someone was going to ask me that and yes i check it everyday before i go to school in the morning
