I have a dream!!! S13 SR20DET into Mazda Miata
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
quick search showed 15-18% drivetrain loss for a 240 so around 500 whp your making 600 at the flywheel,
*edit
new page of your build thread, better get some more pics
mx03tb
Car: 318i
good luck. ok so another update the oil pan has been cut, i will be using the flange only as a prototype to make it a rear sump will be extending the oil pick up to the back and see were that goes. will post up pics soon.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
awe, this will beinteresting
mx03tb
Car: 318i
ok this will be the build thread ill start posting picsssss righttt nowww.
Actually will have to be tomorrow im leaving work now!!!
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Changing your title to attract attention....
Don't disappoint us. :)
mx03tb
Car: 318i
Thank you sir
mx03tb
Car: 318i
Some more pics of the motor mock up. with the 5degree tilt. and the Pulsar ITBs.
Also got in the mail Tomei 740 injectors and z32 maf. and pressure washed the motor. Also bolted up the 2871r and put in all the fittings, Custom lines will have to be made.
Injectors are in!
Clean Motor
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
thats a little inlet on that in take manifold, what is it like 2.5 inches seems like you would want a bigger one since most inter coolerpiping going to the throttle body is 3 inch
mx03tb
Car: 318i
yeah i will be using an inducer that goes from 2.5 to 3"
PyR0NiAk
Why so much tilt?
mx03tb
Car: 318i
its only 5 degress it just looks more cuz its in a miata.
mx03tb
Car: 318i
Hey guys its been a while, been busy with the car. Sorry i haven't posted here in a while. Quick update on the car. New motor is in as well as the transmission everything is looking good for now. I'm working on the wiring harness and getting the new drive shaft ordered. Will post new pics later on today.
PyR0NiAk
mx03tb wrote:Hey guys its been a while, been busy with the car. Sorry i haven't posted here in a while. Quick update on the car. New motor is in as well as the transmission everything is looking good for now. I'm working on the wiring harness and getting the new drive shaft ordered. Will post new pics later on today.
Looking forward to them. ;) These new threads aren't picture flooded enough. Someone actually dug my old one up and forced me to update it... :chuckle:
