Its most likely not your calipers. You have collapsed brake hoses. The hoses have become blocked, by pushing on the pedal you can force fluid pressure past the blockage, but it doesn't not have enough energy to return, this in turn keeps the piston extended.sloweighty wrote: all four of my calipers are sticking and the pads on each sides have the same amount of life, the wired thing about the calipers is that if i drive the car and use the brake more than five times then it will start to stick and heat up real fast and when you need to stop at a stop sign all you have to do is just let go of the gas and then it will start to slow down itself. When the calipers are stick the brake pedal will get real stiff. If i just let it sit for just a couple of hours then it will not stick anymore. So if i am right, my calipers are needed to be rebuild or up grade correct. If anyone can help please help?
Normally a siezed caliper will not retract, even if let sit for a while. I would put my money on collapsed lines. Did you try gravity bleeding?sloweighty wrote: well i bled every side and the brake fluid comes out fine and i do use ATE Blue so i guess i will be up grading.
It would be one hell of a coincidence. If its happening to all four corners simultaneously, I would start looking at your master cylinder or proportioning valve.sloweighty wrote: so if i was to replace my brake lines then i should be good then right, and one more question, is it possible for this to happen on all four sides at once?
yeah, you need a special tool to bend brake lines.. it looks like a tool that you would use to measure an angle... thats because when you bend a brake line you might have to bend it to a cetain angle to fit the car chassis.. its hard to explain what it looks like... just go to a napa or autozone and see if they have it...safin wrote:
^ oh damn thanks, you just answered a lot of questions
im swapping the SR from the hatch to a 510, and while cleaning the 510 noticed that the brake system (brake lines and such) looks terrible plus it had an 'extra' valve i knew it had something to do with the datsun having drum brakes in the rear.
i am swapping all of my brake lines, hoses, valve and master cylinder from the 240......... since we are in the topic of brake lines and suchis there like some sort of tool to bend the brake lines? just using my hands would probably bend them irregularly
to the OP, upgrade to steel braided lines...........
thanks!!
when you press down the brake pedal, you move 2 seperate pistons inside the master cylinder (1 piston for front brakes, 1 for the rear). in each caliper there are 3 major parts to the caliper. the piston, the dust boot, and the piston seal.. when you push on the brakes, the pistons move out, which causes the piston seal to twist, kind of like twirling a rubber band, when you let off the brake, the piston seal naturally wants to untwist its self, causing the pads to release the brake rotor..94_240sx wrote:Proportioning valve is attached to the clutch master sylinder on s13. I was going to suggest taking out the pistons and inspect them, but all 4 corners are doing it, so it should be something else. Lines get separated from master cylinder, so it has to be one central location that control all 4 calipers.
Let me ask you this. I've been wondering about this. You press the brake pedal and pistons come out, right? What happens after you let go of the pedal? Do pistons retract or stay there? You know there's a vacuum line attached to the booster. Does that line retract the pistons? If pistons stay where they are, rotors will touch the pads slightly no matter what.
