I gotta have these headlights.
ride4lame
I got halogen cool blue, and they seem way better then stock. I got them at walmart for like 8 bucks each!
dutch boy
Car: anything with cars/techno music/cruising
Hey guys here's a little help from Amsterdam!!!Check out this site http://members.lycos.nl/my200s...sion/ it works great if you can do this sh*t yourself with some help from other 240 fans!!!!!!!Here in Europe the "normal" 90MM hella units run you about 70 bucks a piece and the HID units are some where around 500 a piece (you can get high and low beam units) . Or you can go for the latest wich is a HID unit with internal E-motor to make the lowbeam/high beam switch. I'm going to make the conversion soon and can post some pics later, i will make the bright white LED park lights in the high beam units while i'm at it.
Good luck and keep those tires smokin......
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
Wow! This is exactly what I've been looking for! Thanks so much. I was wondering if there's any way that you can make the diagram of the housing mounting plate bigger so that I can see the measurements? I have already purchased the components and am trying to fabricate my own mounting plate. Any help you could provide would be great!
-kouki :ylsuper
