just an fyi and it was mentioned above, that there is no such thing as a ground terminal on the starter. the ground terminals are the casing and the start bolts, through the block. the terminal is a + terminal and its always live when your battery is connected. when messing with it always have the battery disconnected. the starter can easily snap your armDarius wrote:I had the same thing happen to me when I reinstalled my head. I don't know how it happened, but the ground terminal on my starter came a little loose. Retorqued it and it fired right up. Also, check the clenliness of the battery terminals and wires. If they are not tight or corroded, it makes a big difference during startup. If you think your battery is dead, just charge it with some jumper cables on your other car. Then, throw it back in there and try to start it again.
Consider that most auto batteries are 6 cells in series (6 cells * ~2V = 12V). If you have a bad cell you are not going to read 12v like he is. OF course it could still be he has a bad battery.gomer23 wrote:Ya just because the voltage reads 12volts doesnt mean anything, If the battery has a bad cell it wont start the car which like Kamin said, is not uncommon.
Kamin wrote:voltage is a measure of poweramperage is a measure of FLOW
i.e. your interior lights run on a 12 volt system at a low amperage, meaning there is little load on the battery and electrical system. your starter runs on a 12v system but uses a TON of amperage. meaning it sucks alot more stored power, faster.
The battery has been ruled out. I'll jack up the car today and check the grounds and make sure that nothing came undone. If everything is in order, I'll pull the starter and take it to autozone (I don't want to take the chance of getting shocked... ).Nameless EJ6 wrote:
Dude keep probing around, you'll find the problem sooner or later.. it's your hybrid!
When you originally heard the clicking... that was a good thing. The starter solenoid was making that noise, but the battery wasn't sufficient enough to keep it clicked down to crank the starter.
So, that should tell you something. Probably need to replace the battery. If you want a quick way to see if it's the battery problem or not, try jump starting with another vehicle. If it cranks and runs while it's connected to the other vehicle.. that's good, it's utilizing that car's charging system. When you disconnect and turn your car off (after running for a while), try to restart again.. if it starts up then your problem is probably solved.. you'll find out for sure though after you do a few shut off and restarts.
Heh. If the battery's been ruled out (maybe you've replaced it?!) and you're still having issues starting, maybe you're not getting a crank or a click out of it, then check to make sure the motor is grounded. There's a few different grounding points from the block to the chassis. Those are extremely critical to your starter circuit..
If you're still having issues and you've ruled out the battery and grounds and all connection points (not half ***'d ruling out).. you're still not getting the starter to crank, then take the starter off and have it tested.
If the starter isn't the problem either.. then ****, you're going to need to go back over it again.. but even more carefully. Get a multimeter if you don't already have one.. back to my original intro when I said "keep probing around"... cuz that's sometimes what it takes to find the answer to stupid problems like this.
I also suggest learning to use the multimeter's functions if you happen to start working with one. Fluke meter's come with some nice literature (well mine did..)..
you won't get shocked.ECU may be an issue as well.. but don't mess w/that till you make sure the starter is good.RB280SX wrote:
Btw, has it dawned on anyone that it could be my ecu? I've been reading around and some people have had problems and got the car to work again by replacing the ecu.
A bad starter/starter solenoid will do that too. AS will poor electrical contacts.RB280SX wrote:Just so everyone gets this straight. The car does not emit clicking sounds. It makes a single click after the initial click of where the electronics turn off. Hence the reason why I didn't think that it was the starter.
