B-TownSX »
https://forums.nicoclub.com/b-townsx-u26146.html
Tue May 27, 2008 8:21 am
My dad and brother put in the engine while I was gone visiting a long distance ex. I was pissed because I didn't get to re-run the heater hoses and check the turbo. So I had to ghetto rig the heater hose which I failed at. I at least got to check the flywheel, clutch, pressure plate, and throw out baring which looked in great shape. The engine has been sitting in my car for about 8 months or so. It's safe to say that it probably hasn't been started in over a year.
1st videohttp://vids.myspace.com/index....822521. I think there's a huge leak somewhere2. You might have noticed that my tachometer is not working3. Stupid heater hose is leaking4. I also need to bleed the clutch, I tried to bleed it from the slave cyl but I was told you have to bleed it from the master as well
2nd videohttp://vids.myspace.com/index....96544 Here is where sh*t hits the fan. A lot of smoke is coming from in between the exhaust mani and turbo. I also have no garage or cherry picker so taking the engine back out is not an option as of now.
