I F-ing HATE rusty hubs!!
jeb1517
Car: 2013 Kia Optima
2015 Nissan 370Z
2005 Honda S2000
Destroyed 2 rotors trying to get this s*** off and still no luck
PorkChopExpress
Car: rb kouki
lol ya it sucks. i put the spare tire on and banged the $hit out of it with a sledge.
NismoZRS
Car: 92 S13 Coupe
ohh s*** you know what thats means... time for 5 lug conversion!! sup sup??
Razi
Car: Moo
My hubs were on a bit tight when I was doing my 5 lug swap.
First I sprayed Liquid Wrench on the hub, then I aimed my breaker bar down onto the hub and started hammering down on the bar until the hub spun.
Then I spray some Liquid Wrench on it and keep spinning it until it pops out.
ZOMG.SR20
Car: 1990 s13
Razi wrote:My hubs were on a bit tight when I was doing my 5 lug swap.
I use ATF and acetone
adrianfromthecastle
Car: 1992 Nissan 240sx
whoa... I've never seen rotors break like that...
lol thats pretty gnarly
jeb1517
2015 Nissan 370Z
2005 Honda S2000
NismoZRS wrote:ohh s*** you know what thats means... time for 5 lug conversion!! sup sup??
lol yea that's the purpose of trying to get it off.
So you hammer down onto one of the 4 lobes that are for the bolts? Didn't think of that but I'm not sure how much more effective that would be but I'll have to try it.
I might just get a 22mm deep socket and remove the knuckle and take it to NAPA to get the hub pressed out. That seems like the most promising solution at this point.
Frankenfourty
Car: 1989 240sx CA18DET
I feel your pain man. I had to spray some penetrating oil on the hub about every couple hours for 2 days to get mine off. Rusty hubs make me wish I had access to a torch.
240tunerguy
Car: s13
torches
ChampaignSilviaS14
Car: S14
You have to twist it, I personally use an air chisel, but a hammer and pry bar might work.
Hit down on it so it spins.
alms24sebring
'04 Nissan Sentra SER SpecV
I would use a hammer and chisel, taking turns beating the hub with a hammer and PB, or said acetone and ATF
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
damn! thats messed up. if they don't come out you may have to press them out. if i was closer to chicago i let you use my 10 ton press. good luck!
Spiffy240
Car: 1992 White 240sx Fastback SE
wow, i avoided this by just swapping out my whole rear uprights for a 300zx aluminum upgright along with 300zx rear 5 lug hubs, brakes, and brake lines
a little more pricey but SOOOOO much better than my crappy old 240sx brakes.Paired with 30mm front brakes and 300zx bmc and booster, omg its amazing the stopping power.
Kalypso
you're doing something wrong... nothing requires that much force...
rubber mallets ftw
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
Did you undo the four bolts in the back? No one has mentioned this
ChampaignSilviaS14
Car: S14
Mine were this bad, and NOTHING will pop them out straight. (Except maybe a press).
jeb1517
2015 Nissan 370Z
2005 Honda S2000
Spiffy240 wrote:wow, i avoided this by just swapping out my whole rear uprights for a 300zx aluminum upgright along with 300zx rear 5 lug hubs, brakes, and brake lines
They're lighter too! That's what I wanted to do but then I would've had to buy new suspension before I could drive it so I didn't go that route.
maj Andres wrote:Did you undo the four bolts in the back? No one has mentioned this
lol yea that's the first thing I did. I would feel soooo salty if I hadn't. Good lookin out tho.
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
mine just came off with a wiggle and a pull when i swapped in my r33 axles. that blows
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
[QUOTE=ZOMG.SR20]
I use ATF and acetone[/QUOTE
qft it works ppl
and wow zomg had a semi-inteligent post............. impressive
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Razi
Car: Moo
Yep, it gets things loose and makes it easier to pull out the hub.
Just making sure..you unbolted the axle from the hub right?
jeb1517
2015 Nissan 370Z
2005 Honda S2000
Yea I did but it's funny you ask that because the passenger side didn't even have the axle nut..WTF! I have to order it I guess. And what's the adjusting nut for that goes with the axle nut, neither side had that on my car.
Oh and everyone always mentions PB Blaster but I've never seen it at the auto parts store (Auto Zone). Do I have to order it online? I might try the acetone and ATF....50/50 mixture??
Razi
Car: Moo
Acetone + ATF works just as, if not better than, PB blaster.
Liquid Wrench is a similar product.
Gcustoms
Car: 1992 240sx LE
did you try and air hammer/chisel?
ZOMG.SR20
Car: 1990 s13
Razi wrote:Acetone + ATF works just as, if not better than, PB blaster.
ATF + acetone has SO MUCH more Penetrating power i used a DROP and it breaks thru bolts
maj Andres
Since you seem to know so much about this technique, what is the mixing ratio?
Side Note: why do you have the I <3 AZ Hitman avatar?
killernoodle
Car: My daily: 2005 Cadillac CTS-V - pretty much stock
Brother's S13 project car: SR20det, wilwoods, suspension, q45 diff/axles, 315s out back
Get a bigger hammer, and don't be a little patsy when you're swinging it.
Try hitting it in a side to side motion to break it loose. Heat if necessary.
Oh, and take the axle out first, doofus.
Spiffy240
Yea man, they are lighter its amazing when I took off the stock ones and put the new ones on how much of a weight difference there is between the whole rear knuckle, brakes, hubs, and all. I love my setup paired with KTS Coils. I would highly suggest in this route. Its a lot more money, but so worth it in the end especially if you plan on going coils. For myself, i massed all my parts during the summer and the last 2 weeks i and a buddy installed everything and tweaked it to work perfect.
GOOD LUCK with getting those hubs off. If you were closer i would gladly stop by and help.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
lol noodle way to rip off my all ready ripped off sig lol I love it. You got the girth, but still falling short
araelzx2
Car: 95 240sx
i hope u took off the big nut thats holds the axel
