I CANT BELIEVE IT HAPPENED AGAIN!!!
sunnys14
Car: S14
i cant believe this... i put all this work into my car and what does it do? it FAILS! my 3rd KA... my 2nd attempt at KA-T. last night, after getting so anxious to get my manifold rewelded because it was leaking, also my exhaust gaskets were leaking, i put it back together. tightened everything back up and got her started. i was so happy to not hear ANY exhaust leaks this time! i rolled it out of the garage, gave it a quick wash in 35 degree weather. went inside to go shower and get ready for a party. i needed to get gas before i left to the party, about half a notch left. i was testing how good 8psi felt, it felt so good. after driving about 1/2 mile, i stopped at a light... conditions felt good (outside temps 35 degrees, not a car in sight. i took it slow in 1st and floored 2nd. when i reached 3rd gear @4200 rpm, the boost gauge held at 8psi... then all of a sudden, i SPIKED to 17psi!!! ****ING cheap TIAL WANNABE WASTEGATE!!!! the car pulled SO HARD, i felt like i was in a spaceship! i thought to myself "oh ****... please dont break down". my friend in the back seat yelled "OMG your car IS ****ING FAST!!" i told him i just spiked to 17psi. then he replied "yeah and theres a WHOLE bunch of smoke coming from your exhaust". Right when he said that, i approached a redlight, and i had to stop. the car died right there as i rolled to a stop. i thought to myself "not again, not again, NOT AGAIN !!" i was about 3 miles from my house. i was NOT about to push my car home again. my friend and i pushed the car to the side of the road in a parking lot where we were at. i tried starting my car like 10 times... it didnt start up at all. i was just sitting there, next to the car in an empty parking lot, then the next thing i know, the highway patrol roll up. they ask me "what seems to be the problem, and i just tell them that my car just died in the middle of the road. the 2 officers look at me and park down the street and scan my plates to check if my car was stolen or not. then i had a crazy idea... i tried to see if push starting the car would work... after 3 times of trying to push start it, it started up!!! with a WHOLE LOT OF SMOKE!!! i had to keep the car revved up above 1500 rpm to keep it from dying. i managed to drive it home with a HUGE smoke screen behind me... i was so sad driving home, knowning that my 2nd attempt of turboing my KA has failed. my first day of driving it... and it fails once again. im sorry guys... but i might have to drop from the KA-T club and gettin an SR... i didnt want to do this but... i cant keep having my car breaking down all the time. its been sittin for the last 4 months and i finally got it driving...
MORAL OF THE STORY: if u have a tial wannabe wastegate, do what i did and take it off your motor and use it as a baseball
klattr1
Car: GT42R powered S14/KA
did that same wastegate work just fine previously in warmer weather?
boost creeping (in colder weather) with BD manifolds is pretty common.
Modified by klattr1 at 1:53 PM 12/6/2005
sunnys14
Car: S14
the same wastegate worked fine in the warmer weather, but i just cant believe it was just spike THAT MUCH! cmon man, 17psi? i dont think its the manifold's there...
klattr1
unless you welded your wastegate closed lol or wastegate side port line popped off, then it could be (overboosting due to manifold design).
BTW, i had a BD manifold for a while. in the winter i could overboost to 22 psi with a 1 bar wastegate spring.
Modified by klattr1 at 8:26 PM 12/5/2005
Jookmasta
the wastegate isnt rerouted is it? also man the boost just reached from 8 to 17 instantaneously? did u trying to let off? probably wasnt enough time either way but my condolences upon ur third loss.
GEO
Car: 95 240sx KA-T
yeh, same thing ahppened ot me.. I was driving my car... it was liek 20 degrees out... I went a tit.. held at 10.5 psi then as soon as it was time to shift ti spiekd to 14-15psi.. I was like OHHHH ****...... but thaknk god ntohing happened... i hope nto atleast, car runs, idles fine... no smoke... WTF.. cold weather. I havea REAL tial wastegate or I think so... Its the one that comes in the IAP kit. car ****kking flew tho..
DammitBobby
Car: S13 91 KA24DET
SUX! I hate hearing it. I have some stock pistons and rods if you want to try and fix it. They are off my old motor that I am not going to rebuild. I have a couple that are not messed up. Hopefully it is only one piston that is messed up. It probably wouldn`t cost to much to fix it. I understand the part of it sitting up and not being able to drive it. That is why I have a daily driver.
fiznat
Car: Grown up :(
Ugh man.. I sorta know how that feels- not on a SECOND motor though. Jeez, I'm sorry
Have you had a chance to look at the motor at all? Compression numbers? Oil leaking anywhere? Anything obviously busted?
LOL I know what you mean about feeling like your car is a space ship hahaha, that one really did make me laugh out loud. Thats how I felt the first time I boosted to 20 psi... it was like w w w w wwooooaahhhhhhh! lol.
jmwenick
Car: 1991 240sx Base Model
Question: If he would have had a boost controller installed, would it have held at 8? Just wondering.
TheOne
Car: 93 240sx FB
that really sux, maybe replace the engine and the wastegate with a real 1 or at least 1 that works:)(and a exhaust mani too:P)
i've had something like that happen to me, i've rebuilt an engine 2 times and then put in another 1 cause the rebuilt 1 died(oth times), and am not even BOOSTED yet!(long story), oh and the 1 thats in there now has a bad hg(drinkin 1 of those fast food big drinks filled with coolant a day), but am still with my car and the ka and i'll keep doin so.
HolyShiznit
Car: Working on my car
This sucks and I feel bad for you but honestly going with an SR while using CHEAP PARTS will simply destroy your SR. Pick up another KA for cheap or build yours. You could have a forged internal built block for roughly the same price as the entire SR swap. Now is the time to think CAREFULLY about what you want to do. Best of luck.
sunnys14
Car: S14
i havent checked compression yet but around were the head and block meet, coolant is dripping from around that area. i was so pissed off at my wastegate that i used a dremel tool to cut it off my downpipe and manifold, poured gasoline on it, and lit it on fire. then i beat it down with a sledgehammer. that made me feel better for a lil while... but anyways, would dumping my wastegate into the atmosphere would have helped a lil?? i checked the wastegate signal line and there was no leaks. i get my signal right off the compressor housing.
Craving4Boost
Car: 91 240sx fastback
trung i told you this is the same way my car boost spiked. fake a** tial wastegate. i'm kind of skeptical now to pick up a BD manifold in replace of my rev hard.
sunnys14
Car: S14
if its just a headgasket that i have to change, i might as well just change it. anyone know if i have to take off both intake and exhaust manifolds to pull the head? usually there are just some heater hoses that i have to disconnect that connect from the block and intake manifold. i just dont understand why BD manifold is so prone to boost creep...
Craving4Boost
it is possible to take off the head without taking off the intake mani...or so ive heard.
Craving4Boost
Geo you said your IAP spikes too? was it the wastegate of manifold?
TheOne
Car: 93 240sx FB
its possible, it shouldn't be too hard to take out the intake/exhaust manifolds and take out the head.....i haven't changed the headgasket on mine(drinkin coolant...somehow), what the pain in the A** is is the timing chain, tho even that shouldn't be too hard as long as you keep the lower timing chain in place without moving a tooth.
nissanfanatic
Car: 1992 Nissan 240sx SE
jmwenick wrote:Question: If he would have had a boost controller installed, would it have held at 8? Just wondering.
*IF* persay you ran an Apexi AVC-R, and the problem was related to cold weather, yes. But when you are running an 8psi spring and pushing 17psi, you can imagine that the wastegate is FULLY OPEN!!.lol
The problem probably was manifold design related. Exhaust gases go along the path of least resistance. If exhaust flows easier through your turbine housing than it does through your wastegate/wastegate flange/wastegate tubing, then guess what? It does just that making more boost.
What kind of smoke was it? White or blue? Did it smell like burned oil? Because 17psi briefly shouldn't really just blow an engine easily... I've spiked close to that before and I have run close to that before(14psi for a full fourth gear pull) and people run more than that as primary boost. Most of the time, it takes a lil bit for detonation/ping to develop... But hey, I wasn't there, and every engine most certianly doesn't react the same...
Quote » but i might have to drop from the KA-T club and gettin an SR[/quote]OMG..... Buy an SR, then buy another ****ty manifold/wastegate and see what happens to the 1337 SR too... They are not engines without problems. They break too. Just as easily as KAs break.
GEO
Car: 95 240sx KA-T
Nope, its casue of the cold air.. and maybe my wategate line.. We will find out soon in 1 week.
huguetpj
Car: 93 KAT Coupe
You can remove the head without removing the manifolds. I did that cause like you I was sick and tired of leaks. Haven't had a leak since my last build, so this build I removed everything attached to the head
Craving4Boost
how come cold air causes boost spikes? is it because the air is denser and it boosts more?
Jookmasta
correct craving4boost.
as for that question about the ebc, so then cory, if he was running a decent ebc with a good solenoid, the ebc would've prevented the spike theoretically?
Craving4Boost
wth..i didnt think cold air makes THAT big of a difference. increase of 5psi and sh*t
Structure240sx
GEO also has a slight obstruction in his dump tube that we have to fix once he is home from school and will let me work on his car
nissanfanatic
I don't know anything about the other EBCs on the market, but the AVC-R uses "self learning mode" when you get the duty cycle right and begin to hold steady boost. So when you overshoot, the "self learning mode" automatically begins to suppress the condition. Its not immediate or anything, but when I overshot to .94kg/cm2 I could see it going down as I stayed in boost. You still have to tune it...
I don't think anything short of running a better designed manifold could have helped him. I mean, if BD screwed up Ryan's manifold as bad as they did, then god knows what was sent out to everyone else...
sunnys14
Car: S14
the reason why i might go SR is because i can run boost while not worrying about a boost spike destroying my motor. stock manifold, stock boost, stock turbo...
sunnys14
Car: S14
i remember i still had the studdering problems at 6k rpms+ is this a bad maf??? i changed my plugs to NGK iridiums and gapped down to .028... it still feels like it studders as if my maf was bad.
KATwo40
Car: 1993 240sx KA-T
Hmmm...interesting.
I'm really sorry this happened to you, man.
Would that manifold have allowed the spiking if he'd been running an interally gated turbo?
nissanfanatic
You won't stay at 180whp will you??
sunnys14
Car: S14
s14 sr20det + megan racing manifold, 14 psi = around 250whp?
