the stuttering in higher rpms could have been your spark blowing out (typically happens in colder weather-denser air = more HP). lowering plug gap will fix that.
obv. pull all of the exhaust side stuff off the head. then pull the intake manifold off the head but dont detach anything. literally pull it off the head and leave it sitting to the side in the engine bay. otherwise you'll hate life later when you are fighting those heater hoses. go ahead and set the motor at TDC so that it will be there when you are setting everything else back up (timing chain, gear alignment and such). take the cam gears off, then all the cam bearing caps in correct order. then pull the cams out and then loosen and remove all the head bolts IN THE CORRECT FSM ORDER. take off idler sprocket, upper timing chain. after that, the head is ready to come off.
after head is off, examine where the HG is blown. it might have little pinholes in certain spots. KEEP UP WITH THE DOWELS that guide the head onto the block.
clean everything REALLY good. dont gouge anything.
if you didnt overheat badly or anything, you are prolly fine to use stock-type headgasket on non-resurfaced head. but i usually have mine checked for level and pressure checked.
put new headgasket on. make sure the orange fire-ring thing is wheres its supposed to be. put dowels back in the block (pinch em in and tap few times). guide the head back on.
then start assembling. use this JWT guide and FSM for cam alignment and such:
http://jimwolftechnology.com/w...E.PDF
make sure to use proper torquing for everything and tighten the head bolts IN THE CORRECT ORDER. its VERY critical. put RTV where it needs to be as well.
be careful with the idler sprocket. its easy to screw up the threads in the head where that goes. make sure it goes in straight.
Modified by klattr1 at 1:05 AM 12/9/2005
