IanS »
https://forums.nicoclub.com/ians-u23642.html
Fri Jan 18, 2008 6:25 am
I would say look into your fuel pressure regulator, it may be sticking causing too much pressure. Also, check the spark plugs, if one of them is blacker than the rest, then you have to suspect an injector failure. Another easy thing to try, is cleaning the mass air flow sensor using some electrical parts cleaner.
