Probably bent your rods.Yogi’sQ45 wrote:I ... put on too small of lower o-rings; they came from NAPA. I read the thread talking about the lower o-rings allowing too much fuel into the cylinder and locking up the engine.
Wow. F*uck.qship96 wrote:If plugs are out and it still wont spin while turning the key, or using a socket on pully- chances are you have major internal engine damage.
Now here is a mystery for me? Pray tell, how would o-rings, of any size, affect the amount of fuel being injected into an engine? I did not read the 0-ring thread but the amount of fuel injected into any engine is a function of the ECU or am I missing something here?Yogi’sQ45 wrote:I have a 94 Q45 with 160,000 miles. I changed the #1 & #8 injectors and put on too small of lower o-rings; they came from NAPA. I read the thread talking about the lower o-rings allowing too much fuel into the cylinder and locking up the engine. I did as it said, I replaced the o-rings and the injectors popped back in perfectly and I pulled the plugs. When I tried to crank it over for a few seconds it wouldn't. I put a socket on the front and tried to turn it manually, but it wouldn't budge. Now what? I would appreciate any and all help. Thanks!
Wow. Guess who's not doing his own #6 injector? This guy.Q45tech wrote:The fuel rail, filter, and lines under pressure hold liters, when you don't entirely remove rail or at least relieve pressure, massive quanities of gasoline fall into cylinder when you remove an injector for service.
56 cc [4 ounces] is enough to hydrolock a cylinder and the system hold 10 times that at minimum!
Common failure when owners or mechanics destroy engines by lack of training and education.
Side feed injectors are very different from top feed injectors and lack of experience can do you in quickly
"The problem with you kids is you missed the sixties." - Hunter S. ThompsonQ45tech wrote:... they need a few joints to calm themselves.
