hydraulic lash adjusters
mikes94q
Car: 1994 Q45 61k
I'm nearly finished on replacing a bent rod in my q. Reading the manual it goes over bleeding the lash adjusters. The only problem is the torx head bolts on the cam caps. It seems like I will be in for alot of problems stripping them, to remove and replace. Is there a good solution to this issue? When I removed the head I never removed the rocker arms so I'm not sure that I need to check them, any input would be great.
I know this was in another post but I could not find it.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Wiggle the rocker arms and if they move more than 1MM then you need to bleed the Hydraulic Lash Adjusters. I hear you on those stupid torx bolts that Infiniti used and You just need to find a good bit that won't break to get them out.
mikes94q
Car: 1994 Q45 61k
Im more worried bout the bolts stripping, I went and got a good tool. But after the second cap the bolts started to strip, so I stopped.
Infinitiguy19
If you don't make too much of a mess you can try a 50/50 mix of Dextron ATF and plain nail polish remover: breaking-loose-rusted-bolts-a-tip-t440010.html
mikes94q
Car: 1994 Q45 61k
any tip on where I can get replacement bolts for the ones that I do ruin?
Infinitiguy19
Here is the part number for the bolts from Infiniti: 13058-60U00- and they go for $2.00 MSRP.
mikes94q
Car: 1994 Q45 61k
any consensus on the easiest way to remove the stripped bolts? The formula worked great but did still have a few that didn't want to come out
Infinitiguy19
You can use pliers along with the ATF/Nail polish formula. Or you can also get a drill bit made to remove stripped bolts, screw...
camshaft-bolt-just-broke-off-in-head-t422976.html
cam-cap-bolts-aaarrrrgggghhhh-t459986.html
