Breaking loose rusted bolts - A tip!
I've always been a big fan of PB Blaster, and I use about 2 cans a year here in my garage. Never thought there was something better - Check it out!!!
Courtesy of GRM:
So you deal with a lot of rusty nuts? Go down to the hardware store and buy some acetone, a quart of Dexron Mercon and a refillable spray bottle. In the spray bottle mix the ATF and acetone in a 1:1 mixture.
Spray away and get your nuts loose!
Independent testing of penetrating oils using a single steel bar with 1/2”x20 nuts torqued to 50 ft/lbs and treated with a 10% salt water solution that was allowed to rust. Listed are the chemicals and required removal torque.
-None ………………… 516 pounds
-WD-40 ……………… 238 pounds
-PB Blaster …………. 214 pounds
-Liquid Wrench ….. 127 pounds
-Kano Kroil ………… 106 pounds
-ATF-Acetone mix….53 pounds
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
sweet info. thanks greg, this will prove quite useful
RCA
Does ATF-Acetone mix have practical uses in the bedroom?
Also this is awesome!
Would out find ATF and acetone in a parts store?Is this mix expensive?
numbnuts240
2011 Ford Focus
2010 Mazda 3
cheaper than pb blaster. total, you'd probably spend somewhere around 10 bucks, but for that, you could have 1/2 gallon worth of rust penetrant.
ScrapMetal
Car: 1999 Chevrolet S10
1991 Ford Bronco 5.0
Cool stuff, I guess I'll give it a try.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
cool, way cheaper than PB blaster
s0m3th1ngAZ
Car: 96' Miata
2014 Focus ST
Damn...our shop must go through a can of PB blaster a DAY...this will prove quite useful.
flohtingPoint
Car: 2004 Z16 Corvette Z06
I'll give it a shot next time I have a bad bolt. Usually if my impact cant take care of it, I bring out my angle grinder/sawzall.
480sx
Car: 1996 Pearl White 240sx
Kroil is the SHT. Omfg, if you get your hands on some you will never use WD, PB blaster, or any of that crap again. I got my hands on some and a good supplier of it about a year ago, and its all we use now.
To bad it smells like cancer.
Neat about the ATF/Acetone, however i mean the kroil is availible in big cans and by the box so, i doubt its practical enough to be used on a wide scale.
numbnuts240
2011 Ford Focus
2010 Mazda 3
480sx wrote:Kroil is the SHT. Omfg, if you get your hands on some you will never use WD, PB blaster, or any of that crap again.
qft. i found a couple of 1/4 full cans in my garage that i ended up using up. s*** is the bomb. i haven't found any in the store yet
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
RCA wrote:Does ATF-Acetone mix have practical uses in the bedroom?
Yes, but it makes my nuts itch.
ADDirishboy
Car: 2008 Nissan Titan Pro4x
I used to use a mixture of acetone and white gas. Worked amazing, but I'm pretty sure the fumes melted half my brain.
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
WD-40 will loosen rusted bolts? Seriously, when was the last time anyone tried that and had it work?
Thanks for the info.
numbnuts240
2011 Ford Focus
2010 Mazda 3
try gold bond next time
DrifterXRPS13
Car: 1993 Acura Integra LS, 1998 Nissan 240SX SE 5sp. KA-T,2004 Honda CBR 600RR, 2005 Suzuki GSX-R 600, 2013 Harley Davidson Iron 883, 2014 BMW S1000RR
Sweet! nice tip greg!
RCA
DrifterXRPS13 wrote:Sweet! nice tip greg!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Does it matter what type of ATF... M1 or Redline synthetic or regualr Dextron 3?
Mr1der
neato.
I'll try to remember this...
<---keeps a baggie of used coffee grounds by the dawn bottle.
I figured this would be a thread about hammers and torches.
krazydriver
Mr1der wrote:<---keeps a baggie of used coffee grounds by the dawn bottle.
hahaha i remember that article!
RCA
Mr1der wrote:neato.
What?
I don't get it?
Red coupe
Car: 92 Nissan 240sx Coupe
Paul Wall wrote:Does it matter what type of ATF... M1 or Redline synthetic or regualr Dextron 3?
I would imagine it would have to do with it both being an oil to lubricate, and having a ton of detergents to help break up gunk.... Just grab what ever :P
Greg, you tried this? Do the two mix well?
I <3 GRM :P
Mr1der
what, the coffee grounds?
use it with dawn to wash your hands after working on a car.
dawn is one of the best degreasers out there, it just lacks the grit that's crucial to scrub off the funk from cars.
the coffee grounds provide this. It seriously works better than any handcleaner I've ever tried. A hell of a lot cheaper if you're a coffee drinker too
Red coupe
Mr1der wrote:what, the coffee grounds?
wonder if dawn and salt would work good... would be cheaper for those of us who hate coffee, and should be grittier?
Mr1der
probably...
and it'll disolve in the drain.
maybe we should just request Dawn make a pumice handcleaner?
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
Definitely some interesting info.
Ghostdrifter88
Car: 2017 Taco
if you need coffee grounds, go to starbucks. if you ask them they will put a bunch in a bag for you for free.
Read please.
Red coupe
Mr1der wrote:maybe we should just request Dawn make a pumice handcleaner?
People DO tend to listen to me...
Mr1der
let's get Jesda to pen the sales pitch.
alms24sebring
'04 Nissan Sentra SER SpecV
I thought PB was pretty good.. Ive honestly never heard of kroil, maybe i should look. ATF + Acetone = bolt breaking win
