Yea they wont sell directly to the public because its so hard core.numbnuts240 wrote:
qft. i found a couple of 1/4 full cans in my garage that i ended up using up. s*** is the bomb. i haven't found any in the store yet
i would think that salt would be the last thing you want to use after your wrench just slipped, busting open the skin covering your knuckleRed coupe wrote:wonder if dawn and salt would work good... would be cheaper for those of us who hate coffee, and should be grittier?
What's funny?480sx wrote:LOL there isnt much as hard core as far as a penetrant-lubricant as acetone and ATF lmfao!
Back in autoshop my teacher used to tell us stories of a study on some guy who wound up with skin cancer. They came to found out that the guy was a mechanic, and would wash up his hands and arms at the end of every day with brake cleaner... I suppose it seemed like a good idea at the time.AZhitman wrote:
Sissy.
I spray brake cleaner on my garage wounds.
Cauterizes it instantly, and if feels REAL good when it stops stinging.
Kroil is specifically made for this industry, and is great stuff. Its a little more tried and tested in MANY different rusted/nasty bolt situations. That was a single lab test.AZhitman wrote:Kano Kroil ………… 106 pounds
-ATF-Acetone mix….53 pounds
Half the force required. Cheaper. Easier to find. Seems pretty cut-and-dried to me.
Does this mystery oil have a name or is it just a generic can. Please share with the rest of the class.C-Kwik wrote:A buddy of mine used to buy some pro-lube crap for his motor. It came with a penetrating oil in a can. Best stuff I've ever used. Fortunately, he was anal retentive enough to keep buying the pro-lube crap so I have a few of his extra cans of the penetrating oil in my garage. Not sure how it compares to everything but liquid wrench and WD-40 (which is a joke). It works better than liquid wrench for sure.
LMAO!Chaotic's Link PDF on Kroil wrote:Inhalation: Remove victim to fresh air.
Not trying to take this out of context so excuse me if i am doing so.C-Kwik wrote: Not sure how it compares to everything but liquid wrench and WD-40 (which is a joke).
I believe it is actually called Pro-Lube. I can double check when I get home. I have a feeling that its actually a rebranded product though. But it does indeed work quite well.Chaotic_Warlord wrote:
Precisely. But the context of the discussion is as a penetrating oil. I have used WD-40 to remove water after honing an engine and washing the cylinder walls with soap and water. It has its purpose. But its not as a penetrating oil...contrary to its primary marketting...480sx wrote:
WD-40 is great for certain things, just not as a penetrant. For a chemical to be effective at breaking loose bolts it has to penetrate through the oxidized metal, and WD-40 simply doesnt do this effectively at all.
Right on it, Chief!AZhitman wrote:
Spray away and get your nuts loose!
Definitely, GRM is chock full of greatness. It's the only car magazine i actually pay to subscribe to.HashiriyaS14 wrote:If GRM has tips like this, I need to start getting it.
