How to wire MSD BTM
PMan_S13
Car: Building car -> breaking car -> fixing car -> start over
Well the instructions are pretty well useless since they are for a different pn completely. I know people have installed these, but no one seems to post exactly how. Maybe this will be the once and for all explanation that I've been looking for.
The s13's have an external coil so we don't need to rip apart the distributer to splice the trigger. I just need to know which wires go where.
I have the following wires available,
-Red Wire-Orange Wire-White Wire-Black Wire-Black and Grey wire that go to a plug -> <- which connects to plug with purple and green wire (I assume this is for the control knob; it also has purple and green wires)-Lastly Purple and green wires that go to a small connector. (I'm guessing this is for a hookup to a magnetic trigger or maybe for a link for a true MSD ignition.)
PMan_S13
bump
Someone out there knows this. I summon thee!
WAbernethy
Assuming you have MSD PN 5462:red-goes to the positive side of the coilblack-any groundorange-replaces wire at neg side of coilwhite-goes to the wire that you take off the neg side of the coilblack and gray are for the control knobgreen and violet are for a magnetic pickup system, not used
I also needed a tach adapter (pn 8910) on my 90' model, so likely you will need it too. It just has two wires that splice in with the red and white wires.
Let me know how that thing works for you. I haven't had much luck with mine. It causes my car to misfire even with the knob at zero. The MSD tech guys had me check a bunch of stuff and then said that my gap must be too big (.032), they wanted me to gap them to .022-.025 to help "fix" the problem. I wound up just bypassing the thing until I get around to taking it out. I'm just going to sell it and hold out for a 6BTM.
WDRacing
You should have the gap set to .028 under boost. You may have a bad ground if its causing problems.
sil80drifter
Car: 1990 240SX Hatch
There seem to be issues with the SOHC ignition signals, I just posted my issues with an SAFC in this thread:
http://www.nissaninfiniticlub....72779
what is UP with the SOHCs?!
sil80
PMan_S13
I plan on just installing the btm for now. If I get problems with the tach then I'll go ahead and grab the adapter from Jeg's in town. If not all let all the DOHC guys know here.
WAbernethy
WDRacing wrote:You should have the gap set to .028 under boost. You may have a bad ground if its causing problems.
I can run .032 with the stock trigger wire and my Blaster coil, no problem. Once I hook in the BTM, it misses every now and then, boost or no boost. I did check the resistance from the spot where I grounded the BTM to a known good ground and it was good. Maybe I'll try moving it to see what happens. Having my timing retarded 5 degrees before the boost even comes on really sucks balls, I'd really like to get it working. This is one of the few things still holding me up from bumping the boost up(Anybody got an extra Z32 MAF?). I was kindof thinking that I may have gooten a bad unit but the MSD guy said that they usually just stop working alltogether.
PMan_S13
Got an email from the techs at MSD today, makes the white/orange wire splicing a little more clear,
"The original coil negative wire should be removed and connected to the white wire. It does not go back to the coil. The orange wire now goes to the coil negative."
Should be able to wire it up easily now, thanks
WDRacing
Sweet...hook up everything and do a write up on it. We need one for all the 240's in the DIY Article forum.
WD
PMan_S13
Once I get my digital camera back I'll take some photos too, I'll send you an email when I get everything together.
daniel240
Car: cars/motocross
^hey WD, how did your btm work out? everthing working ok?
superhoss37
wired up my btm and it sucks really bad. it stumbles under boost around 4k rpms. im pretty sure it's wired up correctly. it's also set to retard .5 per psi
Craving4Boost
Car: 91 240sx fastback
zerothread?id=72633
this should help out
