I'm in Canada and its weird because in my previous car ( Acura TL), I could turn the headlight off manually and the DRL (fog lights, inside housing) would stay on. Before that, I had a Toyota Solara and Lexus ES, the DRL's would stay on but there was a half-globe like plastic piece on my dashboard, which I could disconnect and turn DRL's off.Debonair wrote:US model - Yes, set the headlight to OFF.
Canada or other factory Daytime Running Light model - No. If the car is on, the DRL's will be on.
That sounds like the sunlight sensor which is also used for turning on the head & taillights automatically when it gets dark out.mig0s wrote:I'm in Canada and its weird because in my previous car ( Acura TL), I could turn the headlight off manually and the DRL (fog lights, inside housing) would stay on. Before that, I had a Toyota Solara and Lexus ES, the DRL's would stay on but there was a half-globe like plastic piece on my dashboard, which I could disconnect and turn DRL's off.Debonair wrote:US model - Yes, set the headlight to OFF.
I see the same half-globle thing on my M37's dash. I'll try to pry it op to see if there's a connector under it and disconnect it to see if it will turn the DRL's off.
thanks
its kinda illogical to drive with headlights on n a sunny day at 1pm lolIlya wrote:I'm the complete opposite, I ALWAYS drive my car with the lights on and on my bike as well (bike does it by default though).
For seeing the road ahead of you, yes you are correct. For ensuring all other drivers have the best chance of seeing you it makes perfect sense. It's the whole reason DRL's are used at all, and required in some states / areas / countries.mig0s wrote:its kinda illogical to drive with headlights on n a sunny day at 1pm lolIlya wrote:I'm the complete opposite, I ALWAYS drive my car with the lights on and on my bike as well (bike does it by default though).
I'm the same, I run my HL and fogs at all times.Ilya wrote:I'm the complete opposite, I ALWAYS drive my car with the lights on and on my bike as well (bike does it by default though).
which for the life of me I can never understand why some people refuse to turn on their lights in foggy or rainy weather...so that others can see you...Debonair wrote:..
For seeing the road ahead of you, yes you are correct. For ensuring all other drivers have the best chance of seeing you it makes perfect sense...
Yes. In California, the laws require you to turn on your lights when the wipers are on - even in slow mode. So, in rain, the lights are expected to be on.M37xfan wrote:which for the life of me I can never understand why some people refuse to turn on their lights in foggy or rainy weather...so that others can see you...Debonair wrote:For seeing the road ahead of you, yes you are correct. For ensuring all other drivers have the best chance of seeing you it makes perfect sense...
AFAIK, the DRL's are required by law in Canada, but am not certain. Don't disable them without checking ... you could get a ticket.mig0s wrote:I'm in Canada and its weird because in my previous car ( Acura TL), I could turn the headlight off manually and the DRL (fog lights, inside housing) would stay on. Before that, I had a Toyota Solara and Lexus ES, the DRL's would stay on but there was a half-globe like plastic piece on my dashboard, which I could disconnect and turn DRL's off.Debonair wrote:US model - Yes, set the headlight to OFF.
thanks
Like the picture you showed, there are specific areas where lights have to be on at all times, but I believe, in the US, states do not require DRL's at all times at all locations ... within the entire state, that is.Debonair wrote:and required in some states / areas / countries.
I agree; not for automobiles, not yet. I think Cali requires them for motorcycles and a bunch of other US states want their headlights on full time. But we are getting too far into the fine details at this point I think.szh wrote:...but I believe, in the US, states do not require DRL's at all times at all locations ... within the entire state, that is.
I dont want to disable DRLs... I just want to have parking lights on as DRLs instead of headlights lolDebonair wrote:I agree; not for automobiles, not yet. I think Cali requires them for motorcycles and a bunch of other US states want their headlights on full time. But we are getting too far into the fine details at this point I think.szh wrote:...but I believe, in the US, states do not require DRL's at all times at all locations ... within the entire state, that is.
OP - DRL's are safer to have than not. DRLs are illegal not have some places. Disable at your own risk.
Mic drop.![]()
Thats what I'm saying... In canada our headlights are hooked up as DRLs. Only parking lighta would be enough imonebojsa_o wrote:I am also in Canada, and while I do understand and am ok with DRL's, I don't understand why on the M37 the HID low beams are on as DRL. My 2002 Maxima SE has HID's as well, and when DRL turns on, there are two small separate bulbs that light up the headlight housing. When put to Auto, the HID low beams turn on when it's dark only. With the M37 my low beam HIDs are on 100% of the time the car is running. Is this normal?
mazz wrote:I think if the parking lights which i might call fog lights are on the headlights must also be on.
same in VA. Headlights ON when wipers ON continuously. Does not apply if you just clean the windshield or use it intermittently in light mist/rain.Yes. In California, the laws require you to turn on your lights when the wipers are on - even in slow mode. So, in rain, the lights are expected to be on.
Z
yes we cannebojsa_o wrote:So, can you US guys turn your low beam HID light off in the middle of the day when you put the stalk to OFF position?
You would have to find a way to disable the OE DRL's and the wire up a DRL module to whichever lights you want on as DRL's instead.nebojsa_o wrote:I don't want to disable DRL, I just want it to operate the other bulbs, like on every other car in the country. And apparently like your US models.
