Eikon wrote:It's an Rb25 with Rb20 valve covers I think..
The 25 has that offset on the intake manifold for the 5th and 6th cylander runners.
That engine does have RB20 valve covers, but they are most likely transplanted.
How about some pictures of the front of the engine.. The sure way to tell is if the intake cam has the VVT lobe that sticks out similar to the cam angle sensor on the exhaust side.
the rb25 turbo i put on my rb20 did not have the fitting in the turbo compressor, i had to put it in. Tell the guy to give you 1k back then call it even. hahaCarl H wrote:rb20 in rb25 timing covers and valve covers.
i think the guy is just double checking. it sucks to get scammed like thatOKRB20DET wrote:wasn't this motor already discussed in the show your motor thread?
I took it to a shop in Houston and I was told that it had RB26 Injectors I don't even know anymore.....themadscientist wrote:It's stamped on the block man, look. drivers side (in the US at least) above the oil pan rail at the back of the motor. Those are 260 topfeed injectors so unless they have been changed it's either an RB20DET or an early RB25DE with a turbo put on it.
RB20.IceSkyline25 wrote:Cams
+5 lol took the words right outta my mouth KaminKamin wrote:great it revs higher
dosent change the fact it dosent make as much power. RPM does not equal horsepower
